Software version 0423
Software version 0423 was created by pscan.uk
Posted 7 years 4 months ago #189576
Partial support for Spanish and French, now also available for Linux and MacOSX
Support for Wabco-D ABS ECU. This was developed and tested using an early Freelander 1 ECU however it seems that the protocol is the same as that used on Defenders; we just lack access to a Defender with ABS to try it out. Wabco-D ABS
Much increased list of error codes for RC5EC5 airbag ECU as used on classic MPI and JDM Minis and MGF/MGTF.
The previous version 0422 is here .
Note: we have now tested Wabco-D successfully on a TD5 Defender.
Last Edit:7 years 1 month ago by pscan.uk
Last edit: 7 years 1 month ago by pscan.uk.
The following user(s) said Thank You: sworkscooper, Thierry KZN, Jon-Mini
Replied by Rob Bell on topic Software version 0423
Posted 7 years 4 months ago #189585
What age of Defender do you need access to Philip? I don't have one, but am on the LandyZone forum and could ask around?
Replied by pscan.uk on topic Software version 0423
Posted 7 years 4 months ago #189587
My understanding is that Wabco-D was the only ABS module ever fitted to the Defender. I don't know the years that it was fitted but if a Defender has ABS then it should be relevant. It seems to be quite a rare option on them though.
Posted 7 years 4 months ago #189589
There's a good chance I could be wrong, but thought that this is a Td5 model only? (Which probably means the same unit is also found on the Discovery 2)
Posted 7 years 4 months ago #189591
The Disco 2 had a different ABS module that also did the air suspension, even if it wasn't actually fitted with air suspension.
Posted 7 years 4 months ago #189593
Interesting! :)
Posted 7 years 2 months ago #190186
I found a Defender with ABS. Version 0423 works fine on the Defender as well.
The only issue found so far (with both Defender and Freelander) is that if the engine is not running that the RPM displayed by pscan logged into the ABS ECU is not quite zero.
This will be fixed in a future version.
Time to create page: 5.127 seconds
