Software version 0424
Software version 0424 was created by pscan.uk
Posted 5 years 5 months ago #190622
Live data is now available for the CVT transmission fitted to automatic Rover 25, 45, ZR and ZS and the MGF/TF StepSpeed.
A new menu item has been added under "transmissions" section to access this data.
There is also a feature to reset the adaptations so that the MEMS3 ECU can re-learn a transmission if it has been changed or if the ECU is changed.
Note that a special test drive is required after putting the ECU into this mode, and performance of the vehicle will be extremely unpleasant until this has been done.
Access to the Rover 75/MG ZT GM6 BCU has been added.
Power bleeding of Rover 75/ZT and Freelander 1 (only Teves MK20 so far) ABS modules has been added.
The previous version 0423 is here .
Last Edit:5 years 5 months ago by pscan.uk
Last edit: 5 years 5 months ago by pscan.uk.
The following user(s) said Thank You: sworkscooper, ohnonottwins
Time to create page: 0.555 seconds
