Unknow error code on SRS light 1D1E
Reset the alarms from the Pscan of which we had 2. One disappeared, however the error code we have remaining is 1D1E, so has anyone any idea where I could find where the fault is coming from? My car is an MGF VVC 1997 model. I tried looking for codes on the T-Bar site but could not find anything.
Cheers
Cheers
by Michael1
Error codes with these ECUs are often grouped and related.
For example I know what 120A means and so when a customer on here said that they got 120Y we advised that it was probably the same thing.
Unfortunately I haven't seen anything near to 1D1E at all, and so I can't even guess.
I will try and figure it out but I will need a little time.
Last Edit:7 years 1 month ago
by pscan.uk
Last edit: 7 years 1 month ago by pscan.uk.
Have you had any luck with finding out what code this, I am currently offshore and will be due back home Friday 5th July, as the garage is waiting on news
Michael Reilly
Michael Reilly
by Michael1
I need something called a DTC0058A, or the schematic for one.
At this moment in time I neither have one or a way of getting one.
I have to be honest with you I would put the probability of achieving that by the 5th at 50/50.
I am 90% sure that if you had a code related to something outside the airbag controller (such as a wire / connector or airbag unit) that pscan would know the meaning of the code. Therefore I would say that my best guess is that this is an internal fault in the ECU. This wouldn't be the first time that this has happened.
If I were you I would have a backup plan which would be to find a used ECU on ebay or the like.
Last Edit:7 years 2 weeks ago
by pscan.uk
Last edit: 7 years 2 weeks ago by pscan.uk.
Update.
My chances of delivering this just went from 50/50 to 75/25 as I got a reply here
by pscan.uk
I still can't get my T4 to connect to this Airbag ECU.
The Snap-on Modis does, and for 1D1E it gives me "undocumented code", so a weird one.
I will keep trying with the T4.
by pscan.uk
OK,
So I am looking at ECU's on ebay, the internet is so damned slow out here. I am working on a multi-million pound rig with a threepenny bit internet!
What type of ECU should I be looking at, MGF airbags ECU? I should hopefully be back in blighty next week.
Regards,
Michael Reilly
Regards,
Michael Reilly
by Michael1
Some of them had passenger airbags and some didn't. The replacement one needs to match what you have.
by pscan.uk
1D1E is "ECU internal fault - energy shut-down switch", as stated by my T4
by pscan.uk
OK cool so I might be able to keep the old girl going then, I've had my machine since 2001, what do you recommend get a replacement just the airbag ECU?
Much appreciated
Michael Reilly
Much appreciated
Michael Reilly
Last Edit:7 years 1 week ago
by Michael1
Last edit: 7 years 1 week ago by Michael1.
And what does error code 120a mean, because I have that on my MGF VVC. I can read that it says "Safing sensor not closed", but where to start looking.
by Trond
- exeterjeep
- Novice MGer
hi, have a look at https://www.mg-rover.org/threads/mot-fail-srs-question.640457/ to see if it matches your situation
by exeterjeep
Time to create page: 6.968 seconds
