Unknow error code on SRS light 1D1E
Unknow error code on SRS light 1D1E was created by Michael1
Posted 7 years 1 month ago #190692
Reset the alarms from the Pscan of which we had 2. One disappeared, however the error code we have remaining is 1D1E, so has anyone any idea where I could find where the fault is coming from? My car is an MGF VVC 1997 model. I tried looking for codes on the T-Bar site but could not find anything.
Cheers
Replied by pscan.uk on topic Unknow error code on SRS light 1D1E
Posted 7 years 1 month ago #190693
Error codes with these ECUs are often grouped and related.
For example I know what 120A means and so when a customer on here said that they got 120Y we advised that it was probably the same thing.
Unfortunately I haven't seen anything near to 1D1E at all, and so I can't even guess.
I will try and figure it out but I will need a little time.
Last Edit:7 years 1 month ago by pscan.uk
Last edit: 7 years 1 month ago by pscan.uk.
Replied by Michael1 on topic Unknow error code on SRS light 1D1E
Posted 7 years 2 weeks ago #190782
Have you had any luck with finding out what code this, I am currently offshore and will be due back home Friday 5th July, as the garage is waiting on news
Michael Reilly
Posted 7 years 2 weeks ago #190784
I need something called a DTC0058A, or the schematic for one.
At this moment in time I neither have one or a way of getting one.
I have to be honest with you I would put the probability of achieving that by the 5th at 50/50.
I am 90% sure that if you had a code related to something outside the airbag controller (such as a wire / connector or airbag unit) that pscan would know the meaning of the code. Therefore I would say that my best guess is that this is an internal fault in the ECU. This wouldn't be the first time that this has happened.
If I were you I would have a backup plan which would be to find a used ECU on ebay or the like.
Last Edit:7 years 2 weeks ago by pscan.uk
Last edit: 7 years 2 weeks ago by pscan.uk.
Posted 7 years 2 weeks ago #190785
Update.
My chances of delivering this just went from 50/50 to 75/25 as I got a reply here
Posted 7 years 2 weeks ago #190793
I still can't get my T4 to connect to this Airbag ECU.
The Snap-on Modis does, and for 1D1E it gives me "undocumented code", so a weird one.
I will keep trying with the T4.
Posted 7 years 2 weeks ago #190796
OK,
So I am looking at ECU's on ebay, the internet is so damned slow out here. I am working on a multi-million pound rig with a threepenny bit internet!
What type of ECU should I be looking at, MGF airbags ECU? I should hopefully be back in blighty next week.
Regards,
Michael Reilly
Posted 7 years 2 weeks ago #190797
Some of them had passenger airbags and some didn't. The replacement one needs to match what you have.
Posted 7 years 1 week ago #190827
1D1E is "ECU internal fault - energy shut-down switch", as stated by my T4
Posted 7 years 1 week ago #190842
OK cool so I might be able to keep the old girl going then, I've had my machine since 2001, what do you recommend get a replacement just the airbag ECU?
Much appreciated
Michael Reilly
Last Edit:7 years 1 week ago by Michael1
Last edit: 7 years 1 week ago by Michael1.
Replied by Trond on topic Unknow error code on SRS light 1D1E
Posted 6 years 9 months ago #191681
And what does error code 120a mean, because I have that on my MGF VVC. I can read that it says "Safing sensor not closed", but where to start looking.
by Trond
Replied by exeterjeep on topic Unknow error code on SRS light
Posted 6 years 9 months ago #191682
hi, have a look at https://www.mg-rover.org/threads/mot-fail-srs-question.640457/ to see if it matches your situation
Time to create page: 5.358 seconds
