code names
Unknown Codes 1211 passenger crash censer
1210 drivers crash censer
Known Codes 1805 / 1805 both front belt tensioners
180A right front side airbag
1809 left front side airbag
1803 drivers airbag
So three more to go passenger / and two side skirts
So how to find WHAT is code 1041
1803 drivers airbag
by purjohn
Thanks for the wiring diagrams and pics,
Sorted out the problem, i was the side curtain air bags, removed the connections from both side, the lights out, reconnect and the light is back on
When they where disconnected the pscan did not bring up a fault code !!!!
and the 1041 code is still there, BUT the light is out:clap:
So far.
You help as been fantastic
Thanks again John
Thanks again John
by purjohn
purjohn wrote: Thanks for the wiring diagrams and pics,
and the 1041 code is still there, BUT the light is out:clap:![]()
So far.
Thanks again John
If the ECU does not expect side curtain airbags, and you disconnect them, and the light goes out, I would not expect an error code, because there isn't an error.
Concerning the 1041 code have you tried to delete it? Maybe it will allow pscan to clear it now.
Unfortunately I have no wiring diagrams that show side curtain airbags.
by pscan.uk
1210: Right side impact sensor signal not received
1211: Left side impact sensor signal not received
All of these codes will be added into the next software release.
by pscan.uk
So far.
Thanks again John
Thanks again John
by purjohn
Time to create page: 0.533 seconds
