SAWDOC immobiliser
SAWDOC immobiliser was created by pscan.uk
Posted 6 years 2 months ago #193106
Placeholder for discussions about Freelander 1 SAWDOC immobiliser ECU.
Features are described here http://pscan.uk/features/sawdoc.html
Note that as of release 0429 it is not yet possible to edit the keystore or add new keys. I am waiting for blank keys to arrive so that I can reverse engineer and code this feature.
Replied by pscan.uk on topic SAWDOC immobiliser
Posted 5 years 8 months ago #194519
It turns out that the SAWDOC ECU doesn't support programming of blank key transponder chips.
The way it works is that you have to buy a key from Landrover that's already coded to your car.
Pscan (from version 042B) can then be used to "enable" such as key.
If a key transponder hasn't been pre-programmed to the SAWDOC then pscan won't be able to enable it.
The good news is that a key from Landrover isn't that expensive. The problem is that many of them got rid of their T4s (or never had one in the first place) and so they can supply the key but they can't "enable" it. Pscan can now solve that problem.
Last Edit:5 years 8 months ago by pscan.uk
Last edit: 5 years 8 months ago by pscan.uk.
Replied by daveneedstoknow on topic SAWDOC immobiliser
Posted 2 years 7 months ago #204940
Are there any plans to support programming of remote fobs to SAWDOC?
Posted 2 years 7 months ago #204941
SAWDOC works with a transponder chip in the key. There is a coil on the ignition switch barrel that communicates with the chip in the key.
On the Freelander 1 with SAWDOC the remote fobs are handled by the 27VT CCU and programming of remote fobs is already supported by pscan.
Is that what you meant?
Posted 2 years 7 months ago #204942
Yes that's what I wanted to know. Perfect thanks.
Time to create page: 0.376 seconds
