TD5
TD5 was created by James3990
Posted 4 years 1 month ago #194219
Hello,
New user of Pscan here, glad I finally made the purchase as I own 2 vehicles that are compatible.
First vehicle in question is my LR Discovery 2 (Auto) 300TDI and this was my first test using the tool.
I was expecting some error codes:
[img
I then erased the error codes, drove the car, engine off, ignition back on and double checked for error codes:
[img
Can someone help explain what this means?
I've got an intermittent issue with my braking system, but couldn't seem to find any codes relating to the orange lights eliminated on the dashboard (picture taken after the erase)
[img
Last Edit:4 years 1 month ago by James3990
Last edit: 4 years 1 month ago by James3990.
Replied by pscan.uk on topic TD5
Posted 4 years 1 month ago #194223
Sorry for the slow response.
I took a few days holiday.
You have discovered a bug in pscan and I will have to replicate and fix it.
I am going to guess that the junk text means that there are no error codes.
Could you deliberately disconnect something to create an error code and then read it with pscan and see what happens please?
Replied by James3990 on topic TD5
Posted 4 years 1 month ago #194229
Hello,
Thank you for the reply and no problem about the slow response, we all deserve a break at times!
I do have three orange lights on the dash already (TC, ABS & Hill Decent) which is an intermittent problem, however let me try your suggestion with disconnecting something more obvious and Ill report back over the weekend if it logs any codes.
Regards
Posted 4 years 1 month ago #194241
Are you logging into the vehicle with the menu option "EDC 1.3.1", or with "TD5"?
Posted 3 years 11 months ago #194693
Please can you update to pscan 042C and try it?
I think that I know what caused this and I believe that I have fixed it.
The error codes for the TD5 were a mess. For now I have cleared them out and pscan will show the same error codes that a T4 shows.
I did have other error codes implemented from another tool. I will look at adding them back in. My feeling is that for now most customers will want to see what a T4 would display.
I have also managed to now show which error codes are current and which are historic.
Last the the "extra functions" menu is now back.
At some point I accidentally disabled it.
This menu allows you to view the immobiliser status and sync the TD5 ECU to a 10AS.
Last Edit:3 years 11 months ago by pscan.uk
Last edit: 3 years 11 months ago by pscan.uk.
Time to create page: 0.618 seconds
