Feature Request:- Set Country Code on New 5AS Units (and change on others)
Feature Request:- Set Country Code on New 5AS Units (and change on others) was created by X10Rich
Posted 4 years 1 month ago #194538
Hi I have had a PSCAN for a few years, and I find it is an excellent tool for use on my Rover Coupe VVC & MG ZT 190. but I wondered if it would be possible to add the abilty to PSCAN to program new 5AS units with a country code / Model?
When 5AS units are purchased new, they need to be programmed with a T4. There are still quite a few new 5AS units about, and it woudl be great to be able to program them (I have 2) but also it would allow the interchange of 5AS between models (i.e. the 200 & 400 - there are some differneces to how the 5AS units behave between the models (Bonnet latch is one I know of)
Details from the Rover Technical Bullitin:-
ECU programming:
The new 5AS ECU can only be programmed using TestBook CD - DRE0001
onwards. Use TestBook ‘Diagnostics’ to program ECU.
Select: ‘Security’ - ‘Programming Options’ - ‘Market Program’.
This TestBook sequence will then allow ECU programming to the correct
vehicle type and territory.
NOTE: 400 series 97.5 MY onwards (automatic and manual) and 96 MY (1.6
automatic) cannot be programmed with DRE0001, for these models use
DRE0002.
Thanks
Richard
ECU programming:
DRE0002.
Thanks
Richard
by X10Rich
Replied by pscan.uk on topic Feature Request:- Set Country Code on New 5AS Units (and change on others)
Posted 4 years 1 month ago #194541
I will add it to the list of things to do.
by pscan.uk
Replied by X10Rich on topic Feature Request:- Set Country Code on New 5AS Units (and change on others)
Posted 4 years 1 month ago #194543
Thank you. I can provide new 5AS models if needed
by X10Rich
Time to create page: 0.472 seconds
