Chip tuning with pscan
You can save your existing ECU tune and send it to SAWS. They can then modify the file and send it back to you, and pscan can load it into your MEMS3.
As more information becomes available I will post it here.
And will they be doing the same for MEMS 2.0J?
Yes this is for remapping a MEMS3.
talkingcars wrote: Nice one, what costs are involved?
You would have to talk to SAWS about their prices.
There is no commercial link between pscan.uk and SAWS Tuning. We worked together to produce something that is beneficial to both companies (and customers of both companies).
They are great folks though and I couldn't have done this without their help.
I'm not needing SAWS tune, thanks, nor have I experienced error code 17 so can I stick with 043f please?
I presume that, for now, I can refuse the log-on update, but can you reassure me that 043f won't be swallowed up in subsequent firmware upgrade please?
You can make a copy of your existing pscan folder somewhere else on your harddrive, and then upgrade to version 0430.
If you have any problem with 0430 then you could easily copy the backup folder back and go back to 042F.
If there is any problem with 0430 then I will fix it.
