can PScan sync a MEMS3 ecu?
can PScan sync a MEMS3 ecu? was created by ArntyR
Posted 3 years 10 months ago #194871
Newbie here again.
So, I'm aware that PScan can sync a new fob (with its original 21-digit code) to a TF MEMS3 scu and an original fob must be present to 'start things off' so that this original code can be copied.
Is it possible to sync a different (say a re-mapped) ecu to the same scu/fobs in this same way or is this a completely different process (and one that PScan can't do?)
Of course, this 'new' ecu would be a part no that could work when properly synch'd...but can PScan synch it ?
by ArntyR
Replied by pscan.uk on topic can PScan sync a MEMS3 ecu?
Posted 3 years 10 months ago #194875
The fob is not linked to the MEMS3.
The fob is linked to the Pektron SCU, and then the MEMS3 is linked to the Pektron.
In this respect there are two types of MEMS3.
1. MEMS3 that comes from a 5AS or Pektron car.
2. MEMS3 that comes from an EWS3D car (Rover 75 or 2001 on Freelander 1).
pscan can recode a MEMS3 for 5AS or Pektron, this is referred to as "EMS learning" so yes you can buy a used TF MEMS3 ECU and match it to your TF or move one to a different TF. The alarm/immobiliser will work fine. The only point is that the VIN number coded into the ECU will remain the one from the car that the ECU came from.
Concerning the EWS3D ECUs, pscan has no capability to rematch these. They are permanently linked to the EWS3D immobiliser ECU and so would have to be moved as a matched pair (with keys).
Replied by ArntyR on topic can PScan sync a MEMS3 ecu?
Posted 3 years 10 months ago #194878
Wow, what what a complete and informative answer! Absolutely brilliant..:broon:
So just to be a little more specific, I can bolt another 5AS/Pektron MEMS3 TF135 ecu onto my current 5AS/Pektron MEMS3 TF135 and it will start up and drive without needing any further programming?
I suspect this will be true even if the replacement ecu is from (say) 5AS/Pektron 1.4 Rover 45 which has the same part number as my own 5AS/Pektron 1.8 TF? They'd both be MEMS3...
And at risk of being 'awkward', what if the replacement 5AS/Pektron MEMS3 ecu was new, without a vehicle vin?
(sorry about the repetition; just wanting to be sure)
Last Edit:3 years 10 months ago by ArntyR
Last edit: 3 years 10 months ago by ArntyR.
Posted 3 years 10 months ago #194879
Yes you can fit an ECU from a Rover 25/45 into a TF, and it doesn't matter whether either car is 5AS or Pektron. The 5AS and Pektron EMS protocol is the same.
Concerning bolting in an ECU from another car, the first time you fit the ECU it won't just work. You have to disarm the alarm and then log into the MEMS3 and perform the "learn EMS" procedure. Once you have done this once then it will just work from then on.
Additionally if you now have two MEMS3 ECUs which have both learnt the same Pektron EMS code then they will both work with that Pektron and you can now swap between them whenever you want without further coding.
Note that if you code a MEMS3 to car B then it will no longer work in car A. If you put it back in car A then you would need to learn EMS A again, and now it won't work in B.
With 5AS alarms you can actually reconfigure the EMS code to be the same so that multiple cars all have the same EMS and can share a pool of MEMS ECUs that all have the same EMS code.
I don't remember whether the Pektron has that capability.
Last Edit:3 years 10 months ago by pscan.uk
Last edit: 3 years 10 months ago by pscan.uk.
Posted 3 years 10 months ago #194880
Thanks for the rapid reply. - Again really understandable making me realise that with PScan I can 'fit' a new or spare ecu w/out needing to expensively replace scu/fobs.
Also if I wanted to sell (say) a used re-mapped ecu it can be done w/out accompanying scu/fobs. The buyer would need access to a PScan (or access to working MG diagnostics) to do a 'learn EMS' on his/her own ecu.
So when I get the new ecu I presume I'll bolt it on and the alarm will go off first time I turn the key or try to start it. I'll then disarm the alarm by pressing the 'unlock' button on the fob, then go into MEMS3 on PScan and look for 'learn EMS' and follow instructions?
And will this process work for the SAIC/Continental (NNN000830) ecu? (hi markvrs) I've heard that that there may be some 'internal' changes on the ECU layout, meaning it can't be read in the same process as the earlier MEMS3 versions - even tho' PScan can communicate to cancel 'oil service' light on these models...
Replied by markvrs on topic can PScan sync a MEMS3 ecu?
Posted 3 years 10 months ago #194882
Hi pscan,
Will this work on a SAIC (Chinese) MG TF as well. Have been contemplating this with ArntyR (hi) and am thinking of getting a second hand MG Rover MEMS 3 and using pscan with SAWS download to re-programme it. That would give me a MG Rover MEMS3 with SAWS and a SAIC (Continental) MEMS3 with K-MAP.
If I am reading you correctly after learning the MG Rover ECU the first time , then both ECU's are interchangeable for back to back comparisons or as a spare.
By the way , nice work on pscsan
Cheers Mark
by markvrs
Posted 3 years 10 months ago #194884
ArntyR wrote: making me realise that with PScan I can 'fit' a new or spare ecu w/out needing to expensively replace scu/fobs..
Yes you can. Just change the engine ECU and do "learn EMS". There is no need to change anything else.
ArntyR wrote: Also if I wanted to sell (say) a used re-mapped ecu it can be done w/out accompanying scu/fobs. The buyer would need access to a PScan (or access to working MG diagnostics) to do a 'learn EMS' on his/her own ecu.
Yes this is correct.
ArntyR wrote: So when I get the new ecu I presume I'll bolt it on and the alarm will go off first time I turn the key or try to start it. I'll then disarm the alarm by pressing the 'unlock' button on the fob, then go into MEMS3 on PScan and look for 'learn EMS' and follow instructions?
When you put in a "foreign" engine ECU this doesn't cause the alarm to go off. The alarm will behave normally. What will happen is that when you crank the starter motor the engine will not start. I think that an engine ECU that is receiving the wrong EMS code just doesn't switch on the injectors (though not 100% sure). You can also "read" the immobiliser status of the MEMS3 using pscan so that you can tell if this is happening. The rest of what you say is correct: disarm the alarm/immo, log into the MEMS3 and learn EMS. On screen instructions will guide you through the process.
ArntyR wrote: And will this process work for the SAIC/Continental (NNN000830) ecu? (hi markvrs) I've heard that that there may be some 'internal' changes on the ECU layout, meaning it can't be read in the same process as the earlier MEMS3 versions - even tho' PScan can communicate to cancel 'oil service' light on these models...
To the best of my knowledge the EMS learning stuff didn't change on the SAIC ECUs, and I don't believe that they changed the Pektron either. Concerning fuel maps on the SAIC ECUs I would recommend asking SAWS Tuning because I don't know much about that.
Posted 3 years 10 months ago #194885
markvrs wrote: Will this work on a SAIC (Chinese) MG TF as well.
My confidence is high that it will work, but not 100%. It would be great to verify it.
markvrs wrote: If I am reading you correctly after learning the MG Rover ECU the first time , then both ECU's are interchangeable for back to back comparisons or as a spare.
Yes. If you already have ECU A working in the car, and then you fit ECU B, and do a "learn EMS" on ECU B then this does not change anything in the Pektron or ECU A. What you will have is two engine ECUs A and B, both now with the same EMS code programmed in, both matching the Pektron EMS code, and both working. You would be able to swap back and forth between ECU A and B with nothing more that a spanner. They will both just work.
Posted 3 years 10 months ago #194886
Again, answers of precision and clarity. Thanks for that.
Final request: Please can you outline instructions for PScan to turn water into wine?
Yep, as markvrs said 'nice work on Pscan'. I second that; it's an impressive piece of kit - and still evolving :clap:
Posted 3 years 10 months ago #194887
ArntyR wrote: Final request: Please can you outline instructions for PScan to turn water into wine?
The instructions are here http://www.vatican.va/archive/ENG0839/__PXA.HTM
Note that you need the mother of Jesus, not a pscan.
Posted 3 years 10 months ago #194888
Oh...and I'd just decided that was a better option than playing around with boring ecus.
Please can I get a refund?
by ArntyR
Posted 3 years 10 months ago #194889
ArntyR wrote: Oh...and I'd just decided that was a better option than playing around with boring ecus.
The refund policy is here http://pscan.uk/buy/
Time to create page: 0.519 seconds
