Rover 800 T16
Hi, I was reading an old entry on the Rover 800 forum, and Philip was talking about being unsure of the compatibility of pscan with Rover 800s (especially post 96).
I was just wondering if this was ever resolved?
Thanks - hope to speak soon
by mercedade
pscan appears to work with all of the Engine ECUs except for the Honda ones.
The ones that I have identified:-
T16: MEMS1.6, tested and works (needs 3 pin cable)
KV6 2.5: MEMS2J, tested and works
T-series non turbo: MEMS1.9 tested and works
I believe that the older 4 cylinder cars are using MEMS1.3 or MEMS1.6 and they will almost certainly work. I tried a Montego ECU and that worked and they look similar.
Honda ECUs are not going to work (yet). I think I have a Honda ECU from a 620 but I haven't had a chance to try it out.
by pscan.uk
Ah, that's interesting.
I have a '98 T16 turbo (820 Vitesse) and curious about what I would need.
by mercedade
For a T16 turbo you need a pscan and the optional 3 pin cable.
The T16 turbo ECU is well tested and supported as I have one of these ECUs in the lab.
by pscan.uk
The following user(s) said Thank You: mercedade, alouroverPT
- alouroverPT
- Novice MGer
hello... i need the instructioon sto plug the optional cable and to teste these options... and where can i find the 3 pin plug in the engine bay? thanks
by alouroverPT
Are any 800 owners able to assist? I only have an ECU, not an actual car.
by pscan.uk
Time to create page: 0.529 seconds
