latest pscan update problems
hi all
just updated pscan to the latest version and when i plugged it into my mg zt cdti again there was no option in the diesel list when i clicked the dd3 or dd4 (cant remember which it said now) option iv only got about 5 sensors i can look at and monitor it all worked fine before the last update.
anyone else come across this issue?
by Johnsie
The current version is 042F (on Windows), is that what you have?
When you click on "Diesel engine" you should get five options like this
Are you getting these options?
For a ZT you want DDE4.
by pscan.uk
Hi ya,
yep that's the version I have went out and tried it again this afternoon and it seems to be working OK now so I'm not sure what it was all about the other day but it's all working as it should now thanks
regards
regards
by Johnsie
One thing I noticed is that the injector balance option only appears if you select ISO protocol.
If you select BMW protocol then it doesn't appear. I need to look into that.
by pscan.uk
I did find it weird why there was no option or way of seeing the injector information just thought the program didn't do it, but that's good to know it does might plug it in again tomorrow and have alook after choosing iso protocol
by Johnsie
Well done as you said and checked the injector imbalance via the iso protocol, as it works that way at the moment is there anyway of getting it to read the injectors as your driving? As it is at the moment anything over 1400_1500rpm and they all go to zero
look forward to your reply
Regards
Regards
by Johnsie
Time to create page: 0.660 seconds
