1526 Error Code
Hi all - can someone interpret the 1526 error code for me. Confused about the ignition switch?
1526 pretensioner circuit right ignition switch fault. I also assume that right means the drivers side of the car, a 2004 MGTF 135 single airbag.
Regards
Regards
by Fisher
The meanings of these codes is reverse engineered from other tools as we don't have access to original MG Rover documentation.
My guess is that you probably have a wiring fault associated with the right hand side pretensioner circuit, and the prime suspect for that is the connector under the drivers seat.
Please reply back with what you find; it will help other pscan users.
by pscan.uk
It appears that "1526 pretensioner circuit right ignition switch fault" indicates a fault when you turn the ignition ON, and the DCU goes through its diagnostic sequence. Simply means a fault is found during the cars diagnostics. Also means it involves the pretensioner. So could be one of four things, 1. the pretensioner, 2. the plug on the pretensioner (under the plastic cowl), the under seat connectors, or the pretensioner wires to the DCU.
by Fisher
How did you figure this out? If there is good evidence then I change it from "ignition switch" to "ignition on".
by pscan.uk
HI. I think the current "1526 pretensioner circuit right ignition switch fault" is correct if you think about it. Maybe it should read 1526 pretensioner circuit right ignition switch on fault.
To understand this I was also guided by another forum. As I say once understood it makes sense.
Regards
Robert
Regards
Robert
Last Edit:3 years 2 months ago
by Fisher
Last edit: 3 years 2 months ago by Fisher.
This is exctract from Workshop manual regarding SRS system on MG F cars:
System check
The warning light, located in instrument pack illuminates when the electrical circuits are switched on whilst the system performs a self diagnosis test. If the system finds no fault during self diagnosis the light will extinguish after approximately 5 seconds and remain extinguished. In the event of a fault in the system, the warning light will illuminate continuously or fail to illuminate during the self diagnosis test.
Fault which is read from the SRS ECU with nunber 1526 provides information that after ignition switch was turn to on state SRS ECU found fault in the right hand pretensioner circuit after it performed self test routine.
System check
by Roverlike
The following user(s) said Thank You: sworkscooper, Fisher
maybe "during self test" or something like that would be easier to understand
by pscan.uk
The error code definitions are now updated. See
https://www.the-t-bar.com/forum/pscan-uk-diagnostic-tool-forum/97695-software-version-0433
by pscan.uk
