Finding the EKA
  • PipL
  • Journeyman MGer
  • Journeyman MGer
Finding the EKA was created by PipL
Posted 4 years 8 months ago #197335
Hi, I’m looking for instructions on how to find the EKA code using the pscan
Tia
by PipL
Replied by pscan.uk on topic Finding the EKA
Posted 4 years 8 months ago #197336
Is this with a car fitted with 5AS alarm? or a Pektron SCU?
  • PipL
  • Journeyman MGer
  • Journeyman MGer
Replied by PipL on topic Finding the EKA
Posted 4 years 8 months ago #197337
5AS Lucas
by PipL
Posted 4 years 8 months ago #197339
1. Plug pscan into car diagnostic port (16 pin connector on newer cars (including MGF), green 3 pin connector on cars from the mid 90s).
2. Press unlock on fob.
3. Turn on ignition.
4. Start pscan software and select next:-
5. Select Alarm, immobiliser then select 5AS and select next:-
6. Select Read EKA/KAC:-
The EKA should be displayed after a few seconds.
The following user(s) said Thank You: PipL
  • PipL
  • Journeyman MGer
  • Journeyman MGer
Posted 4 years 8 months ago #197340
That is brilliant thank you so much
by PipL
Replied by Gigi on topic Finding the EKA
Posted 3 years 2 months ago #201846
Hello, why the scan will gave two eka codes?
by Gigi
Posted 3 years 2 months ago #201868
because MG Rover changed the algorithm for the 25 and MGF. If you have a 25, ZR or MGF then it's the top one; if it's a different MG Rover then it's the bottom one.
Posted 3 years 2 months ago #201873
Ok, so in the 45 will gave only one code?
by Gigi
Posted 3 years 2 months ago #201881
No. pscan will always give you both codes. You must decide which one you are going to use.
Posted 3 years 2 months ago #201903
Does it means that both codes could be used?
by Gigi
Posted 3 years 2 months ago #202009
No. Pscan will give you two EKA codes. If you have a Rover 25, MG ZR or MGF then you use the first code. If you have an MG Rover that is not a 25, ZR or MGF, then you use the second code.
Time to create page: 0.436 seconds
