MAC OSX compatibility
MAC OSX compatibility was created by Dgriff
Posted 2 years 11 months ago #198183
Greetings to all. As a newbie to this forum and having recently discovered pecan scanner existence I have been trying to get the pscan program to run with Monterey on a relatively young MacBook Pro before I pull the trigger on the hardware (I assume the scanner is still available)...am I wasting my time? Is there a work around? Will there be an update? Sadly I have an old MacBook Air running Lion I think, that I hoped would be the mule for pscan but at this point in time it has a fault and Im not sure that I can get this running to use the software. Cheers DG
by Dgriff
Replied by talkingcars on topic MAC OSX compatibility
Posted 2 years 11 months ago #198190
Hi
I think you need the hardware so you can interface with the car.
James
Replied by Dgriff on topic MAC OSX compatibility
Posted 2 years 11 months ago #198192
Hi James, thanks for the reply. I would’ve thought that I might see a window come up after selecting pscan with perhaps some input then being required…but nothing happens after 10 mins. So are you suggesting that the emulator is looking for attached hardware to load up operating/display window?
by Dgriff
Posted 2 years 11 months ago #198196
In a word, yes.
The following user(s) said Thank You: Dgriff
Replied by pscan.uk on topic MAC OSX compatibility
Posted 2 years 11 months ago #198217
Can you post a screenshot of what progress you have made? Installing the software and making sure that it works before buying an interface is a pretty good idea.
Posted 2 years 11 months ago #198220
Ok I reckon I've sorted the problem.....I made a mistake in the input string. Now corrected I can get the "Agreement" window and further to that I get to the port selection and language window. Presumably once the hardware is attached I get the option of a USB port selection? So Im thinking its time to get the Scan Tool hardware. Let me know. Cheers.
by Dgriff
Replied by markvrs on topic MAC OSX compatibility
Posted 2 years 11 months ago #198224
Hi Dgriff.
Please come back and let us know how it goes, If it works cleanly I can ditch my old PC laptop I just use for pscan now and move to Mac M1/ Monterey.
:yesnod:
by markvrs
Posted 2 years 11 months ago #198234
Will do. Might be a few weeks before it get the hardware shipped and connected though.
by Dgriff
The following user(s) said Thank You: markvrs
Posted 2 years 11 months ago #198261
I assume that your Macbook Pro is an Intel one and not an M1 chip?
The M1 is not supported at the moment. I could probably get it to work but someone is going to have to lend me an M1 powered Mac to do it. They are just too expensive to justify buying one right now.
Posted 2 years 11 months ago #198263
Yep, Intel...2016 MacBook Pro Monterey 12.1
by Dgriff
Posted 2 years 11 months ago #198264
anyone got a spare M1 powered Mac sitting around that they want to lend me ;)
The cheapest ones seem to be the MiniMac which would do.
I looked at renting one on Amazon AWS but I couldn't understand their pricing. It appears to be cheaper to just buy one then rent on AWS for a month.
Posted 2 years 10 months ago #198494
OK, I have received the hardware and connected to the car. I am now able to progress further into the program which is encouraging. Selecting "Petrol" and "MEMS 3" gets me to a window that is telling me, checking "Checking K Line" and then "K line fault". Seems unusual as I used to have a diagnostic tool that would read the ECU info on this particular car. In anycase I will check the K line continuity/power/connection between ECU and 16 pin plug. Begs the question as I cant find a definitive answer....which pin connections am I checking and for what?...earth, continuity, power? With Thanks DG
PS - I did see the post for..." Mini MPI - K" line fault with an identical problem but not sure if the MEMS 2J would be the same.
Last Edit:2 years 10 months ago by Dgriff
Last edit: 2 years 10 months ago by Dgriff.
Time to create page: 0.556 seconds
