Fuel trims on EMS2000
Is there any way to get short and long fuel trims to show on live data when using pscan on an EMS2000 system?
by pbartlett
Short and long term fuel trims don't seem to be available on the EMS2000, but maybe they show up in EOBD mode.
This might be one of those things that I could add so that you can see them in Rover EMS2000 mode as well.
See if you can get short and long term fuel trims to display in EOBD mode.
If it does then it should be possible to log it to a file as well.
by pscan.uk
Yes can get them on the obd setting
by pbartlett
I need to check which parameters can be read in EOBD mode that cannot in EMS2000 mode.
If you want to speed up the process (because I am very short of time at the moment) then be my guest and post a list of parameter in EOBD mode vs in EMS2000 mode for this particular ECU.
I recently did a similar thing with one of the diesel ECUs so hopefully it shouldn't be too much effort.
Last Edit:2 years 8 months ago
by pscan.uk
Last edit: 2 years 8 months ago by pscan.uk.
Time to create page: 0.488 seconds
