Software version 0435
I had some comments that the Jatco automatic transmission support was not reliable.
It seems that the way a T4 connects to the Jatco in a Freelander is quite different to how it works with a Rover 75, and the Rover 75 method appears more reliable.
This is now implemented as Jatco BMW mode in version 0435.
The previous version is here .
by pscan.uk
- graham.auld
- Novice MGer
hey, not sure if it's just this version I updated to today but I was testing bits on my Pektron SCU and while testing actuators I found the front washers actuator button doesn't work... but if I engage the front wipers using the button next to it and then try to test the washers what I get is a relay in the Pektron clicking perhaps twice a second.
by graham.auld
What I need is someone else to verify this and see if it is a problem with pscan, or with your particular car.
I'm not in a position to do this myself at the moment.
by pscan.uk
Time to create page: 0.389 seconds
