SAWS map experiences?
- BruceTF135
Has anyone used their pscan to install a SAWS map in an MG TF 135? If so, how did it go? I'm thinking of the results rather that the actual act of installing it, which seems straightforward.
by BruceTF135
I have three MEMS3 ECU's for a MG TF135 Standard SAIC MG map, K-Maps remap programmed by K-Maps, and SAWS remap programmed by P-Scan.
Both SAWS and K-Maps give a smoother/nicer throttle response, SAWS seems to have better top end, with K-Maps having a little bit more torque at lower end. This is my subjective view an after several runs swapping ECU's back and forth.
On the stopwatch could not split SAWS/K-Maps.
Cheers, Mark
Cheers, Mark
by markvrs
I had a saws remap at an MG club meet it was via pscan, but by the saws rep, asked a lot of questions about current config and adjusted map to suit, very happy with result, so much better response and overall drive.
by Steve
Time to create page: 0.496 seconds
