Rover 825 Coupe SRS test/reset
- Henrik Kgs. Lyngby
- Apprentice MGer
Rover 825 Coupe SRS test/reset was created by Henrik Kgs. Lyngby
Posted 2 years 10 months ago #204083
Hi,
My Uncle bought a rover coupe 1994/96 (bought from Italy) Now to get the MOT, we have to fix the SRS/airbag-light..
Have one (P-scan) and happy with it
But will it work on this car as well ?
- i haven't seen the car or diagnostic-plug yet, but was told it has 4 pins ? Could that be right ?
Best regards,
Henrik Jensen -Denmark-
Best regards,
Unlikely, but I do have some Rover 800 ECUs in the lab to play with.
If you can photograph the connector then that would help.
by pscan.uk
- Apprentice MGer
Replied by Henrik Kgs. Lyngby on topic Rover 825 Coupe SRS test/reset
Posted 2 years 10 months ago #204085
Ok,
The test connector, i am told, should be a square 4 pin (probably the same as in an early Discovery) i will try to get a picture, one of the next days
Last Edit:2 years 10 months ago
Last edit: 2 years 10 months ago by Henrik Kgs. Lyngby.
- Apprentice MGer
Posted 2 years 10 months ago #204106
Hi,
Here is som pictures of the diagnostic connector, and 1 of the car.
It is from May 1995 Vin: SARRSCCKZAM 175113 -Only airbag in steeringwheel.
It's usermanual say's that a MICROCHECK-tester is needed - i dont know any having one here...
Best regards, Henrik
Last edit: 2 years 10 months ago by Cobber.
- Apprentice MGer
Posted 2 years 10 months ago #204138
Also found this: land Rover Disco1, RR Classic and early RR-P38 is apparently using the same system...
https://landroverforums.com/forum/discovery-i-39/95-disco-resetting-reading-srs-airbag-codes-100711/
Hope it helps.
Regards, Henrik
Hope it helps.
Regards, Henrik
I believe that there are two different SRS systems (early and late). I think that I have a late ECU to play with but an early one.
I will have to have a look.
This will probably take a while I'm afraid.
by pscan.uk
- Apprentice MGer
Posted 2 years 9 months ago #204240
Thats fine, also, it will probably could help some one in future.... -Also for diagnostic on early Range/Land-rover
This one was fixed for now, a land-Rover-collegue have an old aftermarked Range/land-Rover tester that could work with it, it was tested as an Range-Rover Classic 1995/96 -that was able to pull 3 codes,
-2 intermitent, regarding low voltage, probably regarding an earlier bad battery, or some one forgot to remove key before pulling battery terminal.
-1 pressent, regarding "Clock-spring-connector" to steeringwheel. - for now disconnected and a resistor in harness to set lamp off, for an MoT. later to be fixed correct.
(there are some stating that a coupler for a range rover fits and works correct, dispite harness colors are different)
Did your friend connect through the four pin connector in the picture that you posted above?
by pscan.uk
- Apprentice MGer
Posted 2 years 9 months ago #204248
I was not there, but yes, that is what i understand from talking with them
- Apprentice MGer
Posted 2 years 9 months ago #204249
I gues it was a cable like in this link:
https://www.diag-auto.biz/eshop/en/cables/725-t4-cable-airbag-adapter.html
Time to create page: 1.125 seconds
