Coding replacement 5AS to existing ECU
Coding replacement 5AS to existing ECU was created by Yorkshireman
Posted 2 years 3 months ago #206328
Hi, Is the above an easy task please and where do I find the instructions. Thanks.
Replied by pscan.uk on topic Coding replacement 5AS to existing ECU
Posted 2 years 3 months ago #206329
Is it possible to connect pscan to the original 5AS ?
Replied by talkingcars on topic Coding replacement 5AS to existing ECU
Posted 2 years 3 months ago #206330
The instructions are in the program in pscan - make sure you have all the remotes when you programme them as it clears the memory before adding them.
Replied by Yorkshireman on topic Coding replacement 5AS to existing ECU
Posted 2 years 3 months ago #206334
I can re-connect the old one if necessary.
Posted 2 years 3 months ago #206335
Yes
Posted 2 years 3 months ago #206352
Reconnect the old 5AS
Log into the old 5AS using pscan.
Use the "read EMS" feature in pscan and note the EMS.
Fit the replacement 5AS.
Log into the replacement using pscan.
Use the "write EMS" feature in pscan to set it to the value from the original one.
Once you have done this the engine ECU should recognise the replacement 5AS because it's sending the EMS code that the engine ECU expects.
You might have to turn off the ignition and lock the car for the new one to load.
The following user(s) said Thank You: Yorkshireman
Time to create page: 0.382 seconds
