Coding replacement fobs to 5AS Mems 3
Coding replacement fobs to 5AS Mems 3 was created by Yorkshireman
Posted 2 years 3 months ago #206393
Hi, I tried to code 3 fobs to the 5AS. The system successfully coded the first two but would not code the third. What I would like to know is was this because the system can only do two or is my third fob faulty. Thanks.
Replied by pscan.uk on topic Coding replacement fobs to 5AS Mems 3
Posted 2 years 3 months ago #206394
from memory I think you can code upto four, so either faulty or not compatible. There are different part numbers, like 3TXA, 3TXB, 3TXC, 17TN and not all fobs are compatible with all cars. Also there's 315 and 433 MHz.
The following user(s) said Thank You: Yorkshireman
Time to create page: 0.360 seconds
