DIY Cable Length/Pins
I have a pscan from 2016 I've used with an MGF (VVC with Mems2J). I am also now installing a VVC into an MG Midget with original ECU + 5AS. If I wanted to make my own cable for the new installation (with a generic multiplug rather than add an OBD style) are the pinouts for the pscan d-plug end available ? Is there a max length for the cable and do I need to wire the 2x 5AS diag port lines aswell ?
Thanks
Thanks
by DeanoX
in theory it's possible, but 16 pin OBD sockets are easily available and not expensive.
Why not just use a normal OBD socket?
by pscan.uk
Just I have a PC already in the garage - but the std cable wont reach to the car, so was thinking of a longer cable anyway and I have a selection of unused multiplugs already (aswell as some old DB15 shells/plugs for some reason).
by DeanoX
16 pin OBD2 male : 15 pin D-Sub female : purpose
1 : 8 : 5AS data
2 : 7
3 : 6 : 5AS data
4 & 5 : 4 : Chassis
6 : 3
7: 2 : MEMS2J K line
8 : 1
9 : 15
10 : 14
11 : 13
12 : 12
13 : 11
14: 10
15: 9
16 : 5 : +12V
Please be careful because if you get something wrong you can damage the pscan. The most important thing to be careful of is where +12V is connected. +12V to the wrong pin could destroy it. Also earthing through a data line instead of the Chassis pin (for example if earth is missing) can blow out a protection diode.
1 : 8 : 5AS data
2 : 7
3 : 6 : 5AS data
4 & 5 : 4 : Chassis
6 : 3
8 : 1
9 : 15
10 : 14
11 : 13
12 : 12
13 : 11
14: 10
15: 9
16 : 5 : +12V
Last Edit:1 year 10 months ago
by pscan.uk
Last edit: 1 year 10 months ago by pscan.uk.
Many Thanks...cable made and battery connected to the car for the first time in many years. No smoke escaped and PSCAN talking to both ECU and 5AS .
by DeanoX
Time to create page: 0.394 seconds
