Freelander 1 L Series
Hi,
Is it possible to diagnose the cooling fans on a L Series Freelander 1? EDC 1.3.1 diesel ECU
I'm a new owner of a Pecan and I use it on my Freelander 1, it would be great if I could diagnose and activate the cooling fans in the various speeds.
Thanks
Thanks
by Caboz
pscan doesn't currently have that feature. I don't know whether the factory tool does. I'll have to look into it
by pscan.uk
Petrol Freelanders have a single wire from the ECU to the fan system, and it uses some sort of pulse width modulation to vary the speed of the fans (it's not just on or off).
On the petrol ones if the wire between ECU and fan system is disconnected the fans come on full speed.
I don't know if the L series is the same
by pscan.uk
On the L series, if we disconnect the temperature sensor the fans enter in emergency mode, running continuously in full power.
But this does not mean the ecu is able to control the different fan speeds.
I think the factory tool has this possibility.
by Caboz
Time to create page: 0.378 seconds
