Brake lines, The danger lurking.
Brake lines, The danger lurking. was created by MGSED
Posted 10 years 11 months ago #135461
Hi All,
Recently purchased a MGF 1.8i MK2 for the wife, for the princely sum of £300, it was an MOT Failure so set about putting it right.
In doing so I changed the main brake line, front to rear, and from the T piece to the O/S Rear wheel and thought whilst I'm here I'll do from the T to the N/S wheel.
The brake line from the T to the N/S wheel runs above the Air box, and wasn't picked up by the MOT tester as being an issue, as he couldn't see it.
When I removed it, the line snapped in half! Kind of sent the chills down my back.
So thought I'd let you know, might be worth a gander.
I Will try and get some photos up here.
All the best
Stu
by MGSED
The following user(s) said Thank You: Tourbillon, Leigh Ping, coxy134
Replied by John and Sue on topic Brake lines, The danger lurking.
Posted 10 years 11 months ago #135462
Wel done for rescuing an MG.
Well done for pointing out the probs you've found.
But..... For 300 quid the car is going to be a proper snotter with lots of obvious and also hidden probs.
Definitely not a criticism for what you are doing, just the opposite, but keep your expectations low.
And keep being vigilant.
Good luck.
Cue Angry Mob who've bought 300 quid MG's that are 'immaculate'
They're not. :yesnod:
Replied by helsbyman on topic Brake lines, The danger lurking.
Posted 10 years 11 months ago #135486
Yes John people always want gold but only pay for copper
Replied by bensewell on topic Brake lines, The danger lurking.
Posted 10 years 11 months ago #135488
just get some clingfilm round it. Will be perfect.
The following user(s) said Thank You: BarryD
Replied by MGSED on topic Brake lines, The danger lurking.
Posted 10 years 11 months ago #135508
I think you've misunderstood the point here.
I wasn't expecting gold or copper and wasn't expecting a new car! The point of the post is to highlight the fact that the N/S rear brake line isn't easily visible, irrespective of how much the car has cost.
So was saying it could be worth checking out.
I knew what I was buying, and wasn't moaning about it at all.
by MGSED
The following user(s) said Thank You: Leigh Ping, BarryD
Replied by Leigh Ping on topic Brake lines, The danger lurking.
Posted 10 years 11 months ago #135509
Don't worry. I got the point. :broon:
Just don't come round here looking for any more arguments. :bust:
A couple of pics of the offending perished pipe location would be handy for others to check their own. :yesnod:
Last Edit:10 years 11 months ago by Leigh Ping
Last edit: 10 years 11 months ago by Leigh Ping.
Posted 10 years 11 months ago #135525
Lol, Cracking, and trust me never do!
I'll try and sort some out
by MGSED
Replied by cjj on topic Brake lines, The danger lurking.
Posted 10 years 11 months ago #135547
The brake line from the t to my near side rear brake failed when I was approaching a roundabout.
It just burst.
Not as frightening an experience as I expected.
Still wouldn't recommend it though. :nonod:
Replied by Yellow Peril on topic Brake lines, The danger lurking.
Posted 10 years 11 months ago #135561
bensewell wrote: just get some clingfilm round it. Will be perfect.
'And you have a car for sale?'
T'was in jest mon ami :woohoo:
Last Edit:10 years 11 months ago by Yellow Peril
Last edit: 10 years 11 months ago by Yellow Peril. Reason: thought comment may be interpreted as a bit nasty,
Replied by really? on topic Brake lines, The danger lurking.
Posted 10 years 11 months ago #135562
yeah, he's run out of clingfilm. :tada:
by really?
Replied by BarryD on topic Brake lines, The danger lurking.
Posted 10 years 11 months ago #135563
^^^^ Splutters.... At least you know the brake lines are protected from corrosion...
by BarryD
Posted 10 years 11 months ago #135565
Just to confirm I don't fix things with clingfilm... But might be an option and my brakes are working spot on, had to do a sharp stop yesterday as some tool on the roundabout decided to cut across my lane. The 4 pot callipers kicked in spot on and stopped in no time at all.
Time to create page: 0.535 seconds
