ignition probs
  • dave
  • Novice MGer
  • Novice MGer
ignition probs was created by dave
Posted 12 years 5 months ago #138176
ive just bought a 2000 mgf 1.8 , seller told me there was an issue with the key fob , but i drove it on 2 ocasions with no probs so bought the car , on the way home stoped to fuel the car and the imobiliser kicked in , had to be toed home , next day found a guy to reset imobiliser and sell me a new key fob , but car wouldnt start , all lights come on but nothing else , no click from starter ect . guy said needs new battery , bought new battery and same thing ,,,,, guy suggested pushing it down a hill , any ideas ??? hope ive put this in the right place thanks
by dave
Replied by Constantinides on topic ignition probs
Posted 12 years 5 months ago #138180
Not sure if you've gone back to basics before shelling out dosh ..... but I would suggest you check the starter motor there's the main lead leave that ,, then a smaller lead on a spade connection take that lead off clean the connector you can reach in with boot engine access grill removed and feel wire so even a rub with finger can clean connector it enough .. Refit wire and car should start the lead may even of fallen off spade connector if it has refit it.
  • dave
  • Novice MGer
  • Novice MGer
Replied by dave on topic ignition probs
Posted 12 years 5 months ago #138187
thanks pall your a genious , when i did eventualy manage to get to it , one little fiddle and car kicked up first time ,,, now ive gotta go spend a fortune on polish anybody wanna buy a nearly new battery ?????
Last Edit:12 years 5 months ago by dave
Last edit: 12 years 5 months ago by dave.
Posted 12 years 5 months ago #138191
Your :welcome: glad to be of help .
I've only worked on these cars for a short time I'm at the end of a mgf moderate rebuild project , and underneath the shell I'm learning quickly the mgf seems to be a metro with an engine in the back and all metros had same fault on starter motors it's common on the type fitted . Shame about battery .......
Replied by Rick Massey on topic ignition probs
Posted 12 years 5 months ago #138627
I have a MGTF 04 plate 135 with the oval key fob. A couple of weeks ago I drove 300 miles from Norwich-Blackpool with no problems. The car was left on my drive for 2 weeks due to ordering a new rear window etc...
My key fob won't work. Every time I try to start my car it beeps like crazy. I've tried fitting a new battery, charging the battery, jump starting etc... But, it seems like there is an immobiliser problem???
I've been quoted £160-£180 by a local MG specialist who believes its the key fob? He says £80 for key fob plus labour which is steep in my humble opinion.
It's due an MOT in just over one week, I just don't know what to do. I don't want to throw loads of money as I'm in the process of selling it for another car.
Could this fix my problem? Do it myself?...
www.remotekey.co.uk/cars/rover/Rover-oval/default.asp
I've tried the EKA code with no results, and I only have the one key fob. Silly of me really to buy a car with one key fob I know! ;)
Replied by David Aiketgate on topic ignition probs
Posted 12 years 5 months ago #138648
It could be an answer. :shrug: There is also www.MGRovercodes.com that will probably be able to help you with this.
Last Edit:12 years 5 months ago by David Aiketgate
Last edit: 12 years 5 months ago by David Aiketgate.
Posted 12 years 4 months ago #139055
Thanks David.
I've been in contact with a specialist who says he can fix for £70. I've removed my SCU unit from below the Stereo (foot-well area) He says
he will programme me a new key etc... All I need to do is send my SCU to him.
A specialist MG Garage near me wanted £160-£180 to do this!
Cheers,
Rick
Last Edit:12 years 4 months ago by Rick Massey
Last edit: 12 years 4 months ago by Rick Massey.
Time to create page: 0.480 seconds
