heater switch
My heater doesn't go off switch won't go all the way left is it the switch or the rod behind it and is it easy to change
by scubaman
Ooo err your knobs broken
The knobs have a horrible habit of splitting along the shafts, oh my god the more I type this the worse it sounds!
by Mickle5
The following user(s) said Thank You: scubaman
- bryan young
Common problem, yes it can be changed, either a new plastic knob or most go for replacements from B&G , MGF Centre or Mike Satur, Mk1 and Mk2 are different. I have polished aluminium from MGF centre, £30 a set of 3
by bryan young
My knobs ok lol i think its the rear piece as Movement is limited and i have constant heat
by scubaman
Could be the cable is not connected to the valve lever properly.
Pop off the triangular kick panel (driver's side) you'll be able to see where the red cable is attached to the valve.
You can adjust the movement of the dial by moving the outer cable up or down.
Clive's how to
Clive's how to
Last Edit:12 years 1 week ago
by David Aiketgate
Last edit: 12 years 1 week ago by David Aiketgate.
Fixed problem was cable lever had slid off of valve gate Thank you
by scubaman
Time to create page: 1.574 seconds
