New plugs and judders under acceleration
Replied by Sithmaull on topic New plugs and judders under acceleration
Posted 9 years 7 months ago #158130
Yes i have a VVC and what i wanted was the 4 HT leads that go from the spark plugs to the distributor cap.
by Sithmaull
Replied by Plezier on topic New plugs and judders under acceleration
Posted 9 years 7 months ago #158134
But the VVC does NOT have a distributor cap!!! it's the MPi that has the cap. The VVC's leads go direct to the coils
Last Edit:9 years 7 months ago
by Plezier
Last edit: 9 years 7 months ago by Plezier.
- WeekendMonkey
- Journeyman MGer
Replied by WeekendMonkey on topic New plugs and judders under acceleration
Posted 9 years 7 months ago #158137Plezier wrote: But the VVC does NOT have a distributor cap!!! it's the MPi that has the cap. The VVC's leads go direct to the coils
Looking on the Rimmer Bros site shows two options for the VVC, up to 2000 has four HT leads, post 2000 with ECD3 you have the two lead set. A quick Google image search for VVC engines certainly shows examples with four HT leads going under the cover.
Replied by howstar on topic New plugs and judders under acceleration
Posted 9 years 7 months ago #158138
From the photograph you printed you can see four ht l leads it looks like it has distributor cap you should be able to pick thorse leads from good car spares shop
You may need a cap and rotor arm as well
by howstar
Last edit: 9 years 7 months ago by howstar.
Posted 9 years 7 months ago #158141
Exactly as i thought, Thank you.
by Sithmaull
Posted 9 years 6 months ago #158231
Problem cured, replaced the 4th HT lead and all seems well again, no more juddering and drives lovely again.
by Sithmaull
The following user(s) said Thank You: cairnsys, Notanumber
Posted 9 years 6 months ago #158279
Time for an update,
new leads arrived and they were too short, by a long way, even the longest lead wasnt long enough to go from the plug to the distributor. Heres what i think has happened, there are two different sets of 4 leads, one for VVC, the one i needed and one for non vvc engines, the one i received. The non VVC ones are shorter, so i managed to splice together two leads just to check it was the 4th one causing the problem and sure enough it was so she is up and running... well not really. as the lead has been bodged im now waiting to order a proper set of leads so i can replace all 4 with new vvc ones before i can really drive her again. Obviously the guy i bought them from was under the impression that vvc and non vvc ones were all the same so if your buying ones for a vvc please check the cables are very very long otherwise they wont fit. The leads need to go round the engine and then looking through the inspection hatch in the boot you can see where the leads connect near the bottom, i will take photos of this when i get the new leads but its possible to get your hand through to remove the old ones and fit new ones, i didnt have much of a problem with this.
by Sithmaull
Time to create page: 0.526 seconds
