Coolant leak
Coolant leak was created by Tiger78
Posted 9 years 9 months ago #171981
Got home the other night after a good 30 mile run- went out to the car a couple outs later and it had dumped a load of Coolant on the garage floor. There was still coolant left in the header tank. The puddle was to the right of the exhaust box behind the right wheel arch. Took the right rear off to find the area open to the elements - is there a panel missing? Can't find any sign of a leak so topped up the tank and see what happens - any suggestions? Also if anyone knows a mg friendly garage near Aberdeen or Dundee? Would be good to get it on the ramps... thanks in advance
by Tiger78
Replied by davidgv1 on topic Coolant leak
Posted 9 years 9 months ago #171984
Hi,
Sounds like it is the inlet manifold gasket, these manifolds are plastic and do tend to warp over time. Happened to me some years ago, dumped the coolant on the garage floor. New upgraded gasket fitted and all is ok.
Maybe wise to fit a coolant level sensor kit from Brown and Gammons.
Cheers
Replied by Tiger78 on topic Re:Coolant leak
Posted 9 years 9 months ago #171988
Thanks guys - will have a closer look - what is access like and will it require the coolant being emptied?
by Tiger78
Replied by Badger on topic Re:Coolant leak
Posted 9 years 9 months ago #171991
Looking the images It looks like you have a TF not an F so you may well have an alloy inlet manifold which are normally trouble free, however directly below the manifold is the steel coolant return hose and plastic thermostat housing (you may have a remote PRT but the empty thermostat housing is still fitted) on the plastic thermostat housing are 2 "O" ring seals, one at the block end and one at the steel pipe end, if you get a mirror and a torch you will be able to check in that area for leaks.
Brian.
by Badger
Posted 9 years 9 months ago #172002
Thanks Badger,
Yes it's a tf 160. Still trying to find my way around the engine. What's the easiest way to work on these? Access seems pretty limited...
by Tiger78
Replied by talkingcars on topic Re:Coolant leak
Posted 9 years 9 months ago #172007
Have you found the engine access panel?
Another possible cause for a leak is the water pump.
James
Posted 9 years 9 months ago #172018
Talking cars - I have found the panel where it should be but it's missing from my car. Need to get the car higher to have a look...
by Tiger78
Replied by David Aiketgate on topic Re:Coolant leak
Posted 9 years 9 months ago #172019
Last Edit:9 years 9 months ago by David Aiketgate
Last edit: 9 years 9 months ago by David Aiketgate.
Posted 9 years 9 months ago #172033
Well it seems to be running off one of the main pipes under the car - access wise it's a nightmare between the engine and rear bulkhead. If I'm going to change 1 hose - am I as well to change a few? The goose clamps look like they will break so need to stock up before I attempt!!
by Tiger78
Posted 9 years 9 months ago #172068
Well only seemed to be leaking when under load - went round and tightened all hoses up and leak stopped. I do have a small oil leak which seems to come from the top up/dipstick area and running down so that's the next tackle!! Chuffed that it's been fixed.....
by Tiger78
Time to create page: 0.924 seconds
