DISCLAIMER - PLEASE NOTE
These guides have been compiled to allow others to see what T-Bar members have done to their cars, or how they organise runs/meets. The 'How to' guides are intended to show the knowledge acquired, through text, pictures and video, and are purely for demonstration purposes. Use in any projects that you may carry out yourself is purely at your own risk. No responsibility for errors or omissions, in the information here is undertaken. Damage or injury is entirely at the risk of the individual. Hopefully the guides will be of benefit to MG owners as they were intended to be. We have tried to ensure accuracy, but if you note any error(s) please let us know.
ORGANISATION OF MEETS/RUNS
Plan a T Bar Run
Plan a T Bar Meet
How to have a Successful Day
Behaviour at T bar Runs
Advice for Participants
Do not attempt to carry out any work on your car, especially on vital parts, unless you feel competent to do so. Ensure that you carry out any work safely. Always think safety first, and never put yourself in danger.
Categorised A-Z How to fixes - Installation, Improvements, Servicing, Removal, Renovation, Replacement, Detailing, Cleaning, Guidance & Tips.
Scroll down for the full Alphabetical listings, 'Bling mods' (Accessory upgrades) & Video 'how to' section.
HOW TO USE THE T-BAR, MGF FORUM & MGTF FORUM FEATURES
- Explanatory videos.
ALARM
Alarm
- Operating the self test system.
Fob, Alarm
- Cleaning the fob switches.
Fob, Alarm
- Fob replacement guide.
Fob Alarm, Extending Operating Range
- How to increase fob operational range.
Fob Alarm Failure
- Solder repair the key fobs battery cage.
Fob Battery & Keyfob Casing Replace and Resync
- Replacement & resynchronisation guide with video.
Fan Fuse Alarm
- Fitting an audible warning, fan failure device.
ANCILLARIES
Air Conditioning - Retrofit
- Air Conditioning - Retrofitting guide.
Air throughflow vents improvement
- How to improve.
Airhorn compressor upgrade
- Airhorn upgrade.
Airscarf and defroster
- Roof down warmth in sub zero temperatures and how to defrost and demist a frozen rear screen.
Airscarf warm air mods & Clingfilm tip
- Warm air mod uses & screen freeze prevention tips.
Alternator Belt
- Replacing a badly adjusted or loose alternator belt.
Alternator Belt
- Adjusting an ill fitting alternator belt.
Alternator adjuster bracket upgrade
Alternator
- Replacement guide.
Boot Release Remote
- Internal boot release switch mod.
Centre Console
Clock adjustment video.
- Changing the time display setting.
Clock, running slow (Solved).
- MG Clock running slow fix.
Dog Safety Harness Fitting
- Fitting guide.
Fan Fuse Alarm
Fob Battery
- Replacing the battery.
Fob, alarm
Fob Alarm Failure
Funnel (makeshift - touring)
- Prevent oil and water spillage.
Handbrake gaiter
Heated rear Plastic window
- Internal heater fitting mod.
Heated Windscreen Washers
- Warming the washer pipes to prevent ice build up.
IACV
- Removal, cleaning and replacing the valve.
IACV
IACV Reset
- How to reset the IACV.
Instrument Binnacle
- Repair guide.
Locking Wheel nuts
OBD-2 Bluetooth fault code reader
- How to read OBD-2 codes via Bluetooth wifi phone connection.
OBD-2 Fault code reader
How to read all obd fault codes for all versions of Mems.
OBD-2 Fault codes
- Code explanations.
Side Air Intakes
- Adding side air intake scoops.
Stepper Motor
- Removal, cleaning and replacement guide.
Stepper motor
Windstop fitting advice
- How to fit an OEM wind stop.
Windscreen wiper failure
- Applying a temporary 'get you home', emergency fix.
Windscreen Wiper Motor and Linkages
Windstop height reduction
- Reduce the windstop height, preventing window scratches occurring.
BATTERY
Jump start battery change.
- Changing the car battery without losing your electronic codes.
BODYWORK
Arch renovation, sanding and painting
- Renovating guide.
Boot Hinge Replacement
- Removal and replacement guide.
Boot Release Remote
Bonnet gas struts
- Fitting guide.
Bonnet release remote
- Bonnet catch maintenance.
Bumper Front
- Removal guide.
Bumper Rear
Engine Access Panel
- Removal guide (with hoops fitted).
Engine Access Panel
- Removal guide.
Plastic-welding
- Plastic bodywork repair guide.
Scuttle Panel
- Removal and replacement guides.
BRAKES
AP Racing Brakes – How To Remove Seized Pins
- Seized retaining pin removal guide.
Bigger Front Brakes Upgrade
- 240 to 280mm Front Brake Disc Upgrade Guide.
Brake pad challenges - A cautionary tale
- Good advice, worth reading.
Brake Disc Removal (stuck discs)
- Removal guide.
Brake Discs AP Front
Brakes
- Rear caliper replacement guide.
Brake Discs Rear
Brake Disc Wear
- Brake disc wear and advice.
Brake Hoses
- Replacement guide - stainless steel braided hoses.
Brake lines
- Replacement guide
Brake Servo Flex
- Fitting a brace
Handbrake Cable
Handbrake Cables
- Adjustment guide.
Handbrake light
- Flickering display light remedy.
Handbrake Rear Callipers
- Refurbishing guide.
CLEANING & DETAILING
Cleaning Front Arches
- Removing built up debris from the arches.
Cleaning Products
- Recommended products.
Coolant expansion tank clean up
- Cleaning guide.
MG Tyre Valves
- A light-hearted fitting guide.
Paintwork
- Claying guide.
Paintwork
- Cleaning guide.
Paintwork
- How to achieve a polished 'Wet Look'.
Seat cleaning
- Cleaning seat material (not leather).
CLUTCH
Clutch
Clutch Slave Cylinder
- Servicing guide.
COOLING SYSTEM
- Cleaning guide.
Coolant system
- Servicing guide - Bleeding and filling.
Coolant pipes and hoses
- Sizes guide diagram.
Coolant Pipes underfloor
Fan Fuse Alarm
Low Coolant Alarm
- Installation guide.
Radiator
Radiator Fan Warning Light
- How to fit
Thermostat (PRT) Pressure Relief
Thermostat replacement guide
Thermostat replacement pre 2002.
- Thermostat replacement, older type, pre 2002.
ECU - ELECTRONIC CONTROL UNIT
Emerald ECU on MGF VVC mems 1/ 2
ELECTRICS
Adding 12V aux sockets
- Fitting extra 12V aux sockets in your car.
Alarm
Alternator Belt
Alternator Belt
- Adjustment guide.
Alternator
Boot Release Remote
Boot Hinge/Lid Wiring Loom Inspection Guide
Cruise Control
- Fitting.
Bulb List
- Locations and the correct bulbs to use.
Bulb Number Plate Lights
Bulb Side repeater
Circuit Diagrams
- Access guide.
Clock adjustment
- Adjustment guide.
Fan Fuse Alarm
Fob Battery
Fob, alarm
Fob Alarm Failure
Heater Controls
- Illumination guide.
Heater Motor
Hesitation
- Solution discovered.
LED 'how to' wire, resistors
- LED wiring guide.
Light and wiper stalk upgrade using Rover 800/Freelander control stalks
- Fitting guide.
Low Coolant Alarm
- A homemade solution.
- How to read OBD-2 codes.
OBD-2 Fault Codes
Sensors
- Output readings.
Starter Motor
- Remove/replace
Steering left - EPAS
- Rectification guide.
Stepper Motor
- Removal, cleaning and replacement.
Stepper motor
ENGINE
Air filter upgrade installation
- Air filter upgrade installation guide and original airbox removal.
Cam belt
Cam belt timing
- Pics and tips.
Cam Sensor replacement MPI engine(mems3)
- Misfiring solution.
Cam sensor replacement VVC engine
Crank Pulley and gear replacement
Engine Access Panel
- Removal guide, hoops fitted.
Engine Access Panel
- Removal guide.
Engine
- Removal guide.
Engine Fan Test
- Engine fan test video guide.
Engine mounting, Offside
- Replacement guide
Engine options
- MGF - MGTF Engine range.
Exhaust Backbox
Exhaust Daytona
- Sound demonstration.
Exhaust Flexi Pipe
Exhaust Manifold and Flexi pipe
Headgaskets
- by David Aiketgate
Headgaskets
- by Russell Walsh
Hesitation
IACV
IACV
Inlet Gasket
- Replacement Guide.
Induction Kit
- Fitting guide.
Low Coolant Alarm
OBD-2 Fault Codes
Sensors
- Output readings.
Starter Motor
- Remove/replace
Stepper Motor
Stepper motor
Sump Baffle Fitting
- Fitting guide.
Temperatures - Engine and radiator fans
- Info post.
Throttle body 48mm
- Modification guide.
Throttle body 48mm version 2
Throttle Cable
Torque Settings MGF
- Torque values.
Torque Settings MGTF
- Torque values.
Torque Tamer
EXHAUST
Exhaust Backbox
Exhaust choices
- What do they all sound like?
Exhaust Daytona
Exhaust Flexi Pipe
Pipercross Viper Install
EXTERIOR
Boot Release Remote
Bumper Front
Bumper Rear
Cleaning Products
Door removal
- Door removal guide.
Door Window Cheater
Door Mirror Glass
- Glass replacement guide.
Door Mirror (Manual)
Door Window Seals
- Adjustment guide.
Fuel Filler Cap Lock
Fuel Filler Cap
- Polishing guide.
Grills
- Replace and refurbish guide.
Locking Wheel nuts
Paintwork
Side Air Intakes
- Fitting guide.
Spoiler - MGF
- Spoiler fitting guide - MGF.
Splitter K&H
- Fitting guide.
FUELLING
Fuel consumption - Official figures
- Fuel Consumption - MPG Chart & Fuel tank pic.
Induction Kit
- Fitting guide.
MGTF LPG Conversion.
- MG LPG Conversion pics and discussion.
OBD-2 Fault Codes
Syphoning fuel from an MG
- Syphoning fuel from an MGF or TF.
Throttle body 48mm
Throttle Cable
GEARBOX
Clutch
- - Servicing guide.
Gear Change
- Improvement guide.
Gear lever Gaiter
Gearbox
- Filling guide.
Gear cables
MGF Electro Mechanical - CVT
- MGF automatic gearbox info.
MGTF Stepspeed Sports automatic gearbox info - (Steptronic Tiptronic).
- Stepspeed Sports automatic gearbox info.
Mike Satur Slickshift gearstick
- Fitting guide.
Stepspeed Sports automatic gearbox oil level check
- Dipstick checking guide.
GENERAL
Buying an MGF or MGTF
- What you should look for.
Engine options
Finding things on the car
- Parts location guide.
Jacking up an MGF or MGTF car
- Correct 'Jack up' points on an MGF or MGTF car.
Models of F/TF
- MGF - MGTF Models list.
OBD-2 Fault Codes
Paint Codes
- Paint codes with linked photos.
Paintwork
- Claying guide.
Paintwork
- Cleaning guide.
Paintwork
Part numbers
- Finding part numbers.
Sensors
- Output readings.
Service 15k
- 15000 mile servicing guide.
Torque Settings MGF
- Torque settings guide.
Towing
- Towing advice.
Vin number
- Explained.
Wandering
Weekly Checks
- Maintenance guide.
Xpart Centre
- Locations guide.
GUIDES - Members submissions
David Aiketgate.
CJJ.
Broon.
Adam Elphick.
HARD TOP - SOFT TOP
Glass Rear Screen
- Fitting guide.
Glass Rear Screen Video
- Fitting guide.
Hardtop fitting and removal information
- Hardtop advice.
Soft Top
- Adjustment guide.
Soft Top
- Cleaning advice. Lichen, Moss, Mould, Removal.
Soft Top
- Rear seal replacement.
Soft Top
- Removal guide.
Soft Top
Soft Top Sticking
- See video solution below.
HEAD GASKET
Headgaskets
Headgaskets
- by Russell Walsh
How to save a 'soft head'
- by 'Luckymarine' Darren.
Head gasket failure
- by Cobber
HEATING
- Warm your upper back regions, defrost and demist a frozen rear screen.
Heater Air intake
- Upgrading guide.
Heater blower repair
- Heater blower repair guide.
Heater Controls
Heater temperature control knob
- Adjustment
Heater Motor
Rear window, glass heating element repair guide
- Repair guide.
I.C.E - IN CAR ENTERTAINMENT
Door Speaker Renovation
- Renovating the door speakers.
Mike Satur 'FX' Speaker Covers
- Fitting guide.
Sumvision Cyclone Micro 2 media player
- Installed pics.
IGNITION SYSTEM
Hesitation
INSTRUMENTS
Clock adjustment
- Adjustment guide.
Instrument Binnacle
- Repair guide.
Instrument Cluster warning lights
- Display guide.
Instrument Cluster - Iluminated Needles
- Fitting guide.
- Fitting guide.
Lights Interior leds
- Fitting guide.
Oil temp gauge overreading
- Adjustment guide
INTERIOR
Air bag blank
- Rover 25 Cubby box Fitting guide.
Carpets
- Improving fitting guide.
Carpet troubles
- Fitting guide.
Centre Console
Clock adjustment
- Adjustment guide.
Doorcard Change, MGF to MGTF and vice versa
- Doorcard Changing, MGF to MGTF and vice versa.
Doorcard trim holder fix
- Fixing a broken door card trim, holder clip.
Door Pod Swap - Mk2
- Mark 2 MGF Door pod swap.
Door sheet replacement
- How to make a waterproof inner doorsheet replacement.
Gear Change
Gear lever Gaiter
Handbrake gaiter
Instrument Binnacle
- Repair guide.
- Display guide.
- Fitting guide.
- Fitting guide.
Seats
- Removal guide.
Seat Belts
Seats Heated
- Fitting guide (heated pads).
Seats leather
- Renovation advice.
Windscreen trim removal
- Windscreen trim removal guide.
LIGHTING
Bulb List
- Bulb locations and types.
Bulb Side Repeater
Broken MGF front indicator clip fix
- Repair Mod.
Daylight Running Lights - MGF
- DRL, MGF Light Mod.
Daytime Running Lights (Halo) MGTF
- Halo DRLs for the MGTF
Fog lights and switch install - MGTF
- Fog lights installation / electrical wiring guide.
Headlamp - Dipped Beam Headlight Bulb Changing
- Headlamp - Headlight Bulb changing - MGTF H7 55W Bulb.
Headlamp - Main Beam Headlight Bulb Changing
- Headlamp - Headlight Bulb changing - MGTF HB3a 60W Bulb.
Headlights
Headlights
- Trophy headlight type Painting guide.
Improving instrument display illumination
- Visible light upgrade.
Instrument Cluster Warning Lights
- Display guide.
Instrument Cluster - Illuminated Needles
- Fitting guide.
- Fitting guide.
Lights Interior LED
- Fitting guide.
Rear Lamp Protectors
- Fitting guide.
Sidelight Bulb Changing Guide
- MGF Sidelight change and upgrade guide.
- MGTF Sidelight change and upgrade guide.
Tail light bulb upgrade
- MGTF Tail light change and upgrade guide.
Vent illumination guide
- Illuminated side intake vents guide.
LOCKS & KEYS
Bonnet release - opening MGTF - MGF
- How to open an MGF - MGTF Bonnet.
Boot Release Remote
Door Handle Removal
- door handle removal and replacement.
Door lock replacement
- Door lock removal and replacement.
Emergency key access
- EKA CODE - How to use the emergency key access.
Fob Battery
Fob, alarm
- Cleaning guide.
Fob Alarm Fault
Lock - Boot key change advice
- Boot lock adjustment. The 'One key, fits all' mod.
MGF glovebox lock swap
- Changing the MGF glovebox lock.
Passenger Door Lock Jammed
- Unlocking a deadlocked passenger door.
MANUALS
Gearbox Manual
- Gearbox manual download.
K - Series Engine Manual
- Engine overhaul manual download.
MGF Workshop Manual
- MGF manual download.
MGTF Workshop Manual
- MGTF manual download.
Stepspeed / Steptronic Gearbox Manual
- Stepspeed gearbox manual download.
PAINTWORK
- Renovating guide.
Cleaning Products
Headlights
Paint Codes
- Paint codes with linked pics.
Paintwork
- Claying guide.
Paintwork
- Cleaning guide.
Paintwork
Steering wheel painting guide
- MGTF 'Spark' Special Edition Steering wheel paint and refurbish.
Subframe Renovation
- In depth front subframe renovation guide.
SEALS
Door Window Cheater
Door Window Seals
- Adjustment guide.
SEATS & SEATBELTS
Seats
- Removal guide.
Seat Belts
Seats Heated
- Fitting guide, heated pads.
Seats leather
- Renovation guide.
Seat Lowering
- Seat lowering spring fitting guide.
SOFT TOP - HARD TOP
Glass Rear Screen
- Fitting guide.
- Fitting guide.
- Hardtop advice.
Soft Top
- Adjustment guide.
Soft Top
Soft Top
Soft Top
- Removal guide.
Soft Top
Soft Top Sticking
SECURITY
Alarm
Boot Release Remote
Fob Battery
Fob, alarm
Fob Alarm Failure
SERVICING & MAINTENANCE
15k Mile Service
30k Mile Service
- 30000 mile servicing guide.
- Servicing guide.
Coolant system
Weekly Checks
- Weekly servicing checks.
Xpart AutoService centres
- How to find.
SUSPENSION AND STEERING
Alignment and tracking figures
- standard figures
Anti Roll Bar bushes front
Coil Spring replacement for Hydragas spheres
Compliance washers MGF
Hydragas
- Releasing fluid pressure safely.
Lower Front Ball Joint Replacement
- Excessive play solution and guide.
MGF bottom shocker bushes replacement
MGF Brace upgrade
- Fitting a TF brace to an MGF.
Rear Hubs
Rear Track Control Arm
- Refurbishment guide (TRE / Bush)
Rear Track Control Arm inner bush- MGF
Rear Upper Suspension Arm (MGTF)
Steering left EPAS
Steering wheel removal and refit.
- Steering wheel removal and refit guide.
Suspension - Balljoint -Upper front
Suspension Compliance Washers
- Fitting guide.
Suspension - MGF Shocker lower bush
- Replacement guide - Improving wear advice.
Track Rod Ends
Wandering
- Steering checks.
TYRES
Tyre Comparison Sites
- Locator.
Tyre Sizes and Pressures
- Locator.
Tyre Wall Information
- Understanding tyre advice.
Tyres for 15/17” wheels
- Recommended tyres.
Tyres for 16” wheels
Tyre size
- Speedometer reading effects.
Wandering
- Steering checks.
WHEELS AND HUBS
Locking Wheel nuts
- Removal - Replacement guide.
Remove locking wheel nuts without key
Plasti-Dip Wheel Refurb.
- Refurbish your wheels at home with Plasti-Dip.
Rear Hubs
Wandering
- Steering checks.
Stuck wheel and wheel nut solutions
- Removal tips and ideas.
WINDOWS AND GLASS
Door Window Cheater
Door Mirror Glass
Door windows
- adjustment
Door Window Seals
- Adjustment guide.
Glass Rear Screen
- Fitting guide.
- Fitting guide.
Windscreen wiper motor and linkages
Windscreen wiper spring clip fix
- Fitting a spring clip fix to the wiper arm.
Windscreen washer jet nozzle upgrade
- (See video guide below).
Windscreen washer return valve removal
Windscreen wiper - Single arm conversion
- Conversion pics and advice.
Didn't find what you were looking for? Please ask an admin or a moderator.
