2001 mgf 1.8 (gold digger)
Cars - Making me poor since 1989
- onefastmoke
My brand spanking new broken indicator, had only been fitted 2 weeks, it hadn't even had a chance to get dirty lol
once I got the pieces of indicator out found a few cracks around the mounting bolt and where the indicator clips in and some chipped paint
All glued back together and rubbed smooth again
Painted up but one crack is still visible next to the lense, will have to wait another day though as I had another big job on
- onefastmoke
engine cover coming off again
access looks interesting
Started disconnecting whatever I could find but this hose didn't want to let go and brought the pipe with it :shake:
serious glue to the rescue, then used a soldering iron to fuse the outside of it together and seems to be pretty strong
Knuckle hurting bottom bolts
first car I've ever owned where sitting in the boot gives the best access to the engine
cleaning the header tank, lots of tiny bits of copper in here making me think radweld has been used in the past
manifold off but I couldn't physically get it out of the hole so changed my mind and decided to continue with it in situ
lots of coolant round here
this half of the gasket was flat and obviously leaking
this side also flat and leaking but my earlier thoughts of radweld were confirmed, completely blocking the jiggle valve (same cleaned out)
new gasket in
Changed the IACV while it was easy to do so
coolant drained off and all bleed valves opened until empty
bleed valves
changing to pink stuff so lots of flushing was required
once empty the bottom hose was refitted, header tank filled and the system bled
fired the engine and allowed it to warm, gladly the heater got hot as it should and no leaks anywhere
gave it a second bleeding afterwards but no more air came out, just got to keep fingers crossed next few days lol
took her for a celebratory drive (topless of course)
- John and Sue
- onefastmoke
- pendle lass
Is this not a vvc?
- onefastmoke
David Aiketgate wrote: It is possible to get the plastic manifold out intact, just. As I recall you need the airbox out, and you can squeeze it out sideways. Gynaecological skills help! :broon:
I removed my K&N first but completely failed to get it out so just did the few jobs I had in situ, will have to look at changing to alloy in the near future as not sure how long my glued repair will last
- onefastmoke
Whiz wrote: VVC F have alloy manifolds I thought?
Is this not a vvc?
correct its not a VVC so has the lovely plastic manifold. did look for a VVC at the time but most were in terrible condition compared to this one, saying that though if I had known just how much work I was going to end up doing on this one then I would have bought one of the scruffy VVC's :pinch: lol
Aa well as not warping and leaking like the plastic one.
- onefastmoke
David Aiketgate wrote: 1 advantage is that the alloy manifold splits into two. :broon:
does anyone know if a TF135 manifold is a straight swap, mine is a Mems 3 just the same
