List your mod's :D
Replied by Adam-Mgtf on topic List your mod's :D
Posted 16 years 6 months ago #7396
Quicksilver;7372 wrote: just tried lots of suspension components over the years, and some from supposed reputable makers just are not up to the job. Had a set of springs which failed after 2000 miles, and shockers that leaked after a couple of years. Very cautious about what I buy now.
Chris
really? have some makes been better than others? im looking at a GAZ set up, or possibly mike satur all though i don't think his lower the car as much as the GAZ one
Replied by gotenks1321 on topic List your mod's :D
Posted 16 years 6 months ago #7401
Adam-MGTF;7335 wrote: will they be any good for a TF? i need to learn what all the suspention marlarky is about, basically i want to lowed Bucephalus, but i want adjustablilty like you have on a motorbike so i can hacve a softer ride for normal driving but stiffen her up for track days :)
i know the gaz system is good but is around £600 (think from mgoc) but if i can get a good system second hand all the better :)
i need to figure out what else i need to change/ improve such as putting poly bushes in maby?
F and TF suspension is completely different and none of it is transferable from one to the other.
My list is rather small at the moment as i've not added everything to it :lol:
Under the Bonnet:
PRT,
AP racing clutch,
Enclosed K&N,
Milltek backbox,
MS clutch arm,
Shortened gearstick,
MS bell crank kit,
SS flexi-pipe,
SS brake hoses,
Smoothed and polished 52mm throttle body,
Smoothed and polished inlet manifold.
Exterior:
Clear indicator set,
Gaz adjustable shocks,
Lowering pins,
SEAT Leon Cupra R splitter.
Interior:
Colour coded center console, air vents, door handles and door caps,
Leather door card inserts and center armrest,
Windstop,
Half tonneau cover.
To Do:
Ported cylinder head with bigger valves,
Ported & polished(or ceramic coated) exhaust manifold,
Heat coat all induction parts,
Either 1.9 or 2 litre conversion,
Complete front & rear subframe strip down & rebuild,
Alloy refurb,
WON Nitrous kit,
Air intake scoops,
Full silicone hose set,
Electric wing mirrors.
And various bodywork bits and pieces that need doing.
Replied by kara on topic List your mod's :D
Posted 16 years 6 months ago #7415
gotenks1321;7401 wrote: F and TF suspension is completely different and none of it is transferable from one to the other.
Under the Bonnet:
PRT,
AP racing clutch,
Enclosed K&N,
Milltek backbox,
MS clutch arm,
MS bell crank kit,
SS flexi-pipe,
SS brake hoses,
Exterior:
Lowering pins,
Interior:
Windstop,
Half tonneau cover.
To Do:
Alloy refurb,
WON Nitrous kit,
Air intake scoops,
Tis a fine list! - although is a tonneau really a mod? :p
by kara
Posted 16 years 6 months ago #7422
Kara;7415 wrote: Tis a fine list! - although is a tonneau really a mod? :p
Suppose you got me there :o I reckon I could have got away with it if I'd needed to add the studs for it but it's the MK1 that doesn't need anything adding to fit it :skeptical:
Replied by a Guest on topic List your mod's :D
Posted 16 years 6 months ago #7425
gotenks1321;7401 wrote: Under the Bonnet:
Where does the spare wheel go with all that stuff in there???? :whistle:
Posted 16 years 6 months ago #7426
gotenks1321;7422 wrote: Suppose you got me there :o I reckon I could have got away with it if I'd needed to add the studs for it but it's the MK1 that doesn't need anything adding to fit it :skeptical:
Why can I see you going out & buying MK2 fixing studs & modding them to fit a MK1 tonneau just so you can say it's a mod! :lol:
by kara
Replied by David Aiketgate on topic List your mod's :D
Posted 16 years 6 months ago #7428
I suppose a definition of a mod is really anything you add to the car, or is it?
To someone leather seats is a mod, but not to me because the car already had them. :dunno:
So if you don't have a tonneau, then adding one to the car, - is it a mod, or isn't it?
I dunno now, I've confused myself!:dunno::dunno:
Posted 16 years 6 months ago #7429
The Prometheus;7425 wrote: Where does the spare wheel go with all that stuff in there???? :whistle:
Got the perfect spot for that....:whistle:
Kara;7426 wrote: Why can I see you going out & buying MK2 fixing studs & modding them to fit a MK1 tonneau just so you can say it's a mod! :lol:
Nah, gotta be good and pay off the debt man now :frown: Gives me a chance to research and plan everything that I want to do though :yesnod:
David Aiketgate;7428 wrote: I suppose a definition of a mod is really anything you add to the car, or is it?
That works for me :yesnod:
Replied by quicksilver on topic List your mod's :D
Posted 16 years 6 months ago #7439
Adam-MGTF;7396 wrote: really? have some makes been better than others? im looking at a GAZ set up, or possibly mike satur all though i don't think his lower the car as much as the GAZ one
Yes really some makes have been dreadful shoddy, mismatched and just plain dangerous.The Gaz units are pretty good and not bad value for money, can be a pig to set up to get your clearances equal for each coilover, a fraction of a turn on the spring seat different to to opposite corner can put the corner weights out by as much as 10% so very much need to set aside a full day for fitting and setup.
The MS kits are very good and use the same Spax dampers that I have which are great, the springs he uses are very good to but drop the car more then his figures suggest. A TF with the red spring kit will not clear even the tamest speed bump without grounding the floor pan- really a track spring.
Chris
Posted 16 years 6 months ago #7440
Under the Bonnet:
PRT,
AP racing clutch,
Enclosed K&N,
Milltek backbox,
MS clutch arm,
MS bell crank kit,
SS flexi-pipe,
SS brake hoses,
Exterior:
Lowering pins,
Interior:
Windstop,
Half tonneau cover.
To Do:
Alloy refurb,
WON Nitrous kit,
Air intake scoops,
If you want to run nitrous it will be pretty vital to stiffen up the crank and big ends and invest in forged pistons to avoid a very expensive first shot of nitrous, and a sump full of engine bits.
Where were you thinking of getting the head done?
Can point you in the right direction if you are intersted.
Chris
  • figo
  • Going Topless
Replied by figo on topic List your mod's :D
Posted 16 years 6 months ago #7442
Mines Basically Standard :P
Happy new year by the way folks :)
by figo
Posted 16 years 6 months ago #7444
Quicksilver;7440 wrote: If you want to run nitrous it will be pretty vital to stiffen up the crank and big ends and invest in forged pistons to avoid a very expensive first shot of nitrous, and a sump full of engine bits.
Chris
Yep, that's the plan along with the 1.9 or 2 litre conversion :yesnod: Going to really go all out and build it up to handle as much as I can afford.
Not really thought about where yet, I reckon I probably have about a year or so before anything actually starts to happen so plenty of time to look into all the different options and compare them. A couple of first ideas are either Dave Andrews or Modus who are a local company. Any recommendations would be gratefully received :)
Time to create page: 2.958 seconds
