Just cleaned the TF
Replied by David Aiketgate on topic Just cleaned the TF
Posted 11 years 4 months ago #156532
CR41G wrote: Id rather eat my man sausage than let them touch my car again!!!
That's got to be quote of the week! :bust:
Last Edit:11 years 4 months ago by David Aiketgate
Last edit: 11 years 4 months ago by David Aiketgate.
Replied by Blow-in on topic Just cleaned the TF
Posted 11 years 4 months ago #156533
mgtfbluestreak wrote: fancy a low coolant alarm.........thinking of buying the later expansion tank with the sensor in.......are they a pig to wire?......and yes I was also going to ask whats under that sheet next door? is it a escort mk 2 :-? :-? :-? :-? :-? :-? :-? :-?
A seemingly innocent question (the one about the alarm) that could spark considerable debate - 'Lo Alarm' versus 'Brown & Gammons' versus 'home made'. All I can say is that I fitted the Brown & Gammons system and it was very easy to wire. The power comes off the reversing light circuit and they even provided a pigtail joint so it was a straight forward job to just plug it in. Most of your time is spent routing the wiring to the audio unit and light which fit in the central console and even that is straight forward.
Richard
by Blow-in
Replied by Gerry.laing on topic Re:Just cleaned the TF
Posted 11 years 4 months ago #156539
Hi
I fitted the Lolarm only took around an hour and seems to work well, and the car under the cover is a mk 2 GTI Golf been under there for about 4 years now ?
The following user(s) said Thank You: Blow-in, mgtfbluestreak
Replied by Cobber on topic Re:Just cleaned the TF
Posted 11 years 4 months ago #156553
I run the B&G low coolant alarm, and can't speak highly enough about it.
Which ever you choose, your so much better off than not having one.
Time to create page: 0.395 seconds
