Seats - How to remove and refit.
Seats - How to remove and refit. was created by David Aiketgate
Posted 14 years 2 months ago #16681
To remove and refit the seats.
First we need to disconnect the battery, as we will be disconnecting the SRS seat belt assembly cable under the seats. Take care to note any codes etc before disconnecting.
Slide the seats to the rear to enable you to undo the two torx50 bolts, one here and the one under the slider handle.
Now slide the seat forward to expose the rear two bolts here
and here
Now disconnect the srs cable and the only thing keeping the seat in the car is the set belt attachment. Tilt the seat up to get to the bolt.
Note the order, then remove the bolt, spring washer, and the spacer.
Now you can remove the seat, take care of your shiny paintwork, because the sliders are sharp edged. Dropping the top can make removal and refitting easier.
Last Edit:12 years 3 months ago by David Aiketgate
Last edit: 12 years 3 months ago by David Aiketgate.
Replied by David Aiketgate on topic To remove and refit the seats.
Posted 14 years 2 months ago #16682
You should now have something like this
Note that the seat frame has been clamping down on the srs cable. Not good. Take care to ensure this doesn't happen when you refit the seats.
Refitting is simply a reverse of these instructions. When you have fitted the seats, and reconnected the seat belt cables, then connect the battery and turn on the ignition to see if the SRS light indicates that the system is functioning correctly.
Replied by cjj on topic To remove and refit the seats.
Posted 14 years 2 months ago #16684
Good how to mate.
Posted 14 years 2 months ago #16691
Not one of the most difficult, but very handy for fitting heated seat kits.:lol:
Posted 14 years 2 months ago #16758
It's also surprising what you discover under the seats. I found two pound coins, a stainless steel bolt and a washer. Not to mentions lots of crumbs...:shrug:
Last Edit:13 years 8 months ago by David Aiketgate
Last edit: 13 years 8 months ago by David Aiketgate.
Posted 14 years 2 months ago #16776
I know what you mean. I found these guys
Posted 14 years 2 months ago #16824
CJJ;16776 wrote: I know what you mean. I found these guys
...chanting 'All hail CJJ!'?
Replied by bryan young on topic To remove and refit the seats.
Posted 14 years 2 months ago #16837
You dont clean under the seats then! - very good how to, the bit about disconnecting the battery first is essential, i understand that you can fire an air bag if the SRS system capicatitor is not discharged!!
Posted 14 years 2 months ago #16856
David Aiketgate;16824 wrote: ...chanting 'All hail CJJ!'?
How did you know?
Posted 14 years 2 months ago #16857
Bryan Young;16837 wrote: You dont clean under the seats then! - very good how to, the bit about disconnecting the battery first is essential, i understand that you can fire an air bag if the SRS system capicatitor is not discharged!!
I would always advise people to disconnect the battery first, it's just something I never practice myself.
Posted 14 years 2 months ago #16870
I must admit I tend to overlook disconnecting the battery myself, but in writing a How-to you do have to err on the side of safety.:yesnod:
Posted 14 years 1 month ago #16881
If the how-tos from us suddenly stop, you know why. :)
Time to create page: 0.515 seconds
