Re: Steering to the left? EPAS fault.- How to cure it.
Steering to the left? EPAS fault.- How to cure it. was created by David Aiketgate
Posted 14 years 11 months ago #7198
The EPAS fault.
Does your steering pull to the left? Does it seem to be worse at slow speeds? Is it easier to turn left than to turn right? Or rarely, the opposite might be true.
If the answer is yes to all of these questions then it could be the Epas fault.
What's that then?
Epas is simply the Electrically Power Assisted Steering.
Basically, the steering is assisted by an electric motor. There is a sensor on the steering column that detects when you turn the wheel and triggers the motor to assist.
Unfortunately, it is quite common that over time, the sensor becomes misaligned. This usually results in the sensor telling the motor to help turn left even when you want to steer straight ahead.
To test whether this is the problem:-
1 Safely jack up front of car.
2 Centralize the steering wheel.
3 With car in NEUTRAL, switch on engine. Watch steering wheel, if it turns to the left ( or right) all by itself you need to adjust the EPAS sensor.
To adjust the sensor:-
4 Turn off engine, re-centralize wheel.
5 Disconnect battery.
6 Open compartment under steering wheel.
7 Undo two bolts holding fuse box, and move it aside. Wrap the fusebox in a plastic bag to guard against shorts later.
8 Behind there, on the steering column you'll now be able to see the sensor covered by a metal shield, remove shield.
9 The sensor is held to the steering column by two bolts in adjustment slots.
10 The slots are filled with a glue/filler, to prevent the sensor from moving.
11 Dig out the filler material from the slots in the sensor.
12 Loosen the two bolts holding the sensor. (Do not remove them!)
13 Rotate the sensor a small amount. Hand tighten the two bolts.
14 Making sure that the fuse box is safe, reconnect the battery.
15 Start the car and observe the steering wheel. If it moves less or moves more slowly, you have turned the sensor in the correct direction.
16 As necessary, repeat steps 4 to 13 until the steering wheel doesn't move from the centralized position..
17 When you're happy repeat steps 4 and 5.
18 Tighten bolts properly, use silicon sealant or glue to fill the slots up again.
19 Refit the shield and then the fuse box.
20 Reconnect the battery, and check the steering wheel still doesn't move.
21 Close up the compartment under the steering wheel.
22 Let the front of the car down.
23 Test drive.
24 Have a coffee and pat yourself on the back!
For further information and photos, have a look at this site:-
http://www.mgf.ultimatemg.com/group2/common_problems/epas_reset/index.htm
The site explains a more technical method of centralizing the sensor as well as the method above.
Last Edit:3 years 6 months ago by David Aiketgate
Last edit: 3 years 6 months ago by David Aiketgate.
Replied by David Aiketgate on topic Steering to the left? EPAS fault.
Posted 14 years 4 months ago #14962
I've revisited this 'How to' as, although the steering wasn't self steering left anymore, it still turned left more easily than right. So I decided to try adjusting the EPAS sensor by the slightly more technical method as described on the www.mgf.ultimatemg.com website.
The method is the same as the previous method, up to and including point 11.
Before loosening the two bolts on the sensor(point 12), Follow the cable from the sensor, it is connected into the wiring loom at a plug attached to the steering column behind the sensor position. You can pull the connector off the column and then disconnect it.
If you look at the plug from the sensor, you will see 4 pins connected to the 4 coloured wires. (Red) 5+v; (Black) -v; (Yellow) sensor output; and (Green) sensor output.
Basically you need to run a 4 to 6 volt battery through the red and black wires. Then you connect a voltmeter across the green and yellow pins. Initially on 0-2 volts scale. Then on 0-200 millivolt scale.
What you are looking for is a 0 volts reading across the sensor pins.
With the steering in the straight ahead position, I got an initial reading of 0.070volts, and as I say the steering was OK, but was definitely easier to turn left.
Keith Starbuck (author of the article on the website) recommends less than 10 millivolts.(0.010volts)
I then loosened the sensor bolts and moved the sensor until I got as near 0.000volts as I could.
I managed to get it down to 0.002volts.
So I re-tightened the bolts and checked again. Still 0.002 volts.
I then refilled the slots with silicone sealant.
I reconnected the plug and cable-tied it to the steering column in the same position.
I then followed the rest of the above 'How-to', from point 19.
On the test drive the steering felt much better balanced, with no bias either way. Result!
Total time - about 1 hour. Not a difficult job.
Edit - I found that the job was easier when I undid the two bolts that hold the frame (that the fusebox attaches to) and moved that aside, as well as the fusebox.:yesnod:
Replied by David Aiketgate on topic Re: Steering to the left? EPAS fault.- How to cure it.
Posted 14 years 1 month ago #17773
Having done three of these on the service day, there are two additional points to mention:-
1/. There is an older type sensor with 6 wires instead of 4. I could not adjust this sensor using a multimeter.
I adjusted it with the first method.
2/. The job is easier if you remove the main plastic fascia cover. It is held in by 2 screws. Loosen these 2 screws and pull the cover off.
Replace after the adjustment is complete.
Last Edit:9 years 3 months ago by David Aiketgate
Last edit: 9 years 3 months ago by David Aiketgate.
Replied by chrisd300 on topic Re: Steering to the left? EPAS fault.- How to cure it.
Posted 13 years 2 months ago #29491
HI I have this problem with my mgf, it wants to steer to the left at slow speed, should i turn the sensor clockwise or anticlockwise. please can you help me thank you. Chris.
Posted 13 years 2 months ago #29492
chrisd300 wrote: HI I have this problem with my mgf, it wants to steer to the left at slow speed, should i turn the sensor clockwise or anticlockwise. please can you help me thank you. Chris.
You really need to use a multimeter to get it right. The adjustments are so small that you could spend a lot of time fiddling back and forth. :yesnod:
I can't recall offhand which way you adjust it, as it's been a while since I did one. :nonod:
The following user(s) said Thank You: chrisd300
Replied by MrMaltby on topic Re: Steering to the left? EPAS fault.- How to cure it.
Posted 12 years 2 months ago #76676
Thanks for this guide, was a great help in fixing the self-steering!
Posted 12 years 2 months ago #76822
:broon: Glad it helped!:yesnod:
The following user(s) said Thank You: Zebra
Replied by Zebra on topic Re: Steering to the left? EPAS fault.- How to cure it.
Posted 9 years 3 months ago #162179
Did this the other day, using the multi meter method. Pretty straightforward after reading David's guide ( along with advice pointing to the multimeter instructions, so thanks to those chaps too). We no longer turn left at every opportunity.
The cover over my sensor assembly was held on with two bolts, which also had pozi slots in the top. They were pretty soft, and on quite tight, so my advice is to be careful you get your screw driver at the correct angle because it was easy to trash the slots. Well, it was on mine, whilst hanging upside down under the dash!
When connecting the meter, I found the spade terminals a bit big, so I cut them in half and tightened them slightly with pliers.
Excellent instructions, thank you; I don't know how you have the patience to photograph every step! Mind you, I'm glad you do.
by Zebra
Replied by cbjroms on topic Re: Steering to the left? EPAS fault.- How to cure it.
Posted 1 year 7 months ago #201932
This information really helped me today. Used the multimeter method and was done in an hour. Trial and error would seem to me to be a very time consuming method. Thanks again.
by cbjroms
Replied by knfevg on topic Re: Steering to the left? EPAS fault.- How to cure it.
Posted 10 months 4 weeks ago #205515
Did anyone had luck understanding how to do the multimeter thing in an older 6 wire sensor?
by knfevg
Replied by Notanumber on topic Re: Steering to the left? EPAS fault.- How to cure it.
Posted 10 months 1 week ago #205728
Without the benefit of the multimeter method on the 6 wire sensor I came up with a variation that makes the trial and error method easier.
Seperate the steering column UJ at the foot of the column.  Theres just a single pinch bolt and and you can just retract the bottom part of the column a bit as it's telescopic.
Get 2 LEDs. ( I used some that were made for warning lights that had inline resistors.  ) Wire the LEDs in parallel back to back but the opposite polarity from each other so that whichever way voltage is applied one of the LEDs will light up.  ( you can check this on a 9v battery if you have one)
When you have the LEDs wired back to back like this you need to push the two wires into the larger of the EPAS connectors. Push one in with the heavy Brown/ Red wire and the other in with the Brown/ Blue wire.
Turn on the ignition and start the engine.  If the setup is correct then neither LED should light and turning the wheel should flas one LED with the same amount of force in either direction. Adjust the sensor until this is a achieved and then tighten the torx screws on the sensor.  Refil the slots with gunge as has been recommended.
Reattach the universal joint, it only will fit one way so turn the wheel til it slides onto the splined shaft. Push the UJ downwards onto the spline so you can refit the pinch bolt. Double check this has been done correctly.
The car should now drive without any bias right or left from the EPAS.
Last Edit:6 months 4 days ago by Notanumber
Last edit: 6 months 4 days ago by David Aiketgate.
The following user(s) said Thank You: David Aiketgate, talkingcars, Airportable
Replied by DavePro on topic Re: Steering to the left? EPAS fault.- How to cure it.
Posted 10 months 1 day ago #205861
Another possibility for checking EPAS output is pscan. I found that mine gave Target and Observed current. With both at zero, my EPAS seemed in good shape. Twiddling the wheel gave fascinating changes to all the figures. Maybe this would work for someone adjusting the pot. pscan.uk gives the EPAS data provided in Features.
by DavePro
Time to create page: 1.184 seconds
