Re: Plama Dials - How to fit.
First one is in daylight, if you look at the gauge on the far left you can just see the clear Perspex below the needle paint and in the second taken minutes before posting this, the effect when the lights are on.
Replied by David Aiketgate on topic Re: Plasma Dials - How to fit.
Posted 13 years 4 weeks ago #29917Mal7921 wrote: The Citroen dash pics are below, and yes it is high milage but still does a good average mpg and has full colour sat nav, not bad for a 2001 car
That's what I'd like for the MG dials. :yesnod:
First you need a light source so that means adding leds in behind the dials. :pinch:
If I get chance tomorrow I'll have another look behind and get some pictures, and I'll get the needle put on right at last!
What I could do with now is one of the Rover dash pods to examine, or pictures of one stripped down so I can see the construction of the dials...
Posted 13 years 4 weeks ago #29940Needles
Illumination kit
I really like the effect that these give! :yesnod:
It could be possible to fit these though we would have the issue of milo miter memory. Would be a good starting point though as they are rover parts
- Leigh Ping
Johntwedd1 wrote: I managed to fit the dials without removing the steering wheel. It was a bit of a squeeze but is do able, also I used small pieces of double side tape on the corners (out of sight) to hold them in place when re-fitting.
It can be done without removing the steering wheel then? In that case, I might try removing the yellow plastic light filter to improve my speedometers white light display.
Posted 12 years 4 weeks ago #79532David
Lee
- Andy Lawrence
I put the dimmer switch in the same place too! Spooky! :broon:
Just waiting for it to get dark so I can see them lit up :woohoo:
Only thing different I did was not take steering wheel off!!!
I have the heater control set to fit but wonder what I can do with oil temp and clock dials cos they look odd now.
Any ideas???
WHALE OIL BEEF HOOKED
