Re: Plama Dials - How to fit.
Replied by David Aiketgate on topic Re: Plasma Dials - How to fit.
Posted 12 years 4 weeks ago #79558
Last Edit:12 years 4 weeks ago by David Aiketgate
Last edit: 12 years 4 weeks ago by David Aiketgate.
The following user(s) said Thank You: Andy Lawrence
Replied by Leigh Ping on topic Re: Plasma Dials - How to fit.
Posted 12 years 4 weeks ago #79559
Andy the tyre man wrote: Any ideas?
Mod them with a coloured, transparent insert.
Replied by pendle lass on topic Re: Plasma Dials - How to fit.
Posted 12 years 4 weeks ago #79566
David I've got the illuminating needles now and they don't have pins in. the pins for the temp and petrol gauge have stayed attached to the original needles that I've removed from the cluster.
did this happen with yours? if so what have you done? did you cut the pins and clue them to the new needles?
gonna have another look at this this week :broon:
Posted 12 years 4 weeks ago #79570
It did, Tracy. :pinch:
I carefully removed the pins from the old pointers and glued them into the new pointers.
Be careful, because the pins are very brittle. I broke one trying to pull it out of the old pointer.
I would either try cutting the pointer away from the pin or melting the pointer, rather than using force.
I had to buy another instrument pod to get another pin, :lol: :nonod:
The pins were also not a tight fit in the new smaller pointers so needed gluing anyway.
Posted 12 years 4 weeks ago #79572
thanks David found the how to for the needles now :broon:
Posted 12 years 4 weeks ago #79816
Andy the tyre man wrote: I have the heater control set to fit but wonder what I can do with oil temp and clock dials cos they look odd now.
Any ideas?
Here's another good idea that you could consider Andy.
Replied by fast jan on topic Plasma Dials - How to fit.
Posted 11 years 3 weeks ago #132763
Sorry for the thread revival, but it seemed the most apt place to ask my question - is there any logical reason that the oil gauge & time clock lights wouldn't work after fitting the plasma dash dials & heater panel? :-? (The plasma bits were already fitted when we bought the car).
There is a power supply to the clock & gauge.
Replied by David Aiketgate on topic Plasma Dials - How to fit.
Posted 11 years 3 weeks ago #132765
Jan,
There's no reason for them not to illuminate from fitting the plasma dials per se. Mine are working fine.
It's probably going to be down to some damage caused in the fitting. A disconnected wire or a fuse.
Do the switches illuminate because I think they're on the same fuse.:shrug:
Just thinking aloud, does the supply come via the standard dash lighting rheostat? Is that still wired up?
Posted 11 years 3 weeks ago #132768
Thanks David :) Yep everything else illuminates fine, and the fuse is also fine.
What's a rheostat and where would I find that? :-?
Posted 11 years 2 weeks ago #132773
Sorry. The dimmer switch. :dry:
If everything else lights up then it's got to be down to the live feed to those gauges, unless both bulbs have gone...
Replied by 135.Lizzyy on topic Re: Plama Dials - How to fit.
Posted 2 years 4 months ago #199479
A bit late to the party but have been thinking about installing this kit, any chance you still have the photos to re-upload at some point? Many Thanks :)
Replied by David Aiketgate on topic Re: Plama Dials - How to fit.
Posted 2 years 4 months ago #199484
I lost a lot of photos due to hard drive failure some time ago. I do have a few MG photos left but unfortunately the Plasma dials pics are not amongst them.:nonod:
Time to create page: 0.586 seconds
