Starter Motor -How to remove/replace
Replied by talkingcars on topic Starter Motor -How to remove/replace
Posted 2 years 2 months ago #206871M10
15mm head
90mm long shaft
18mm head on bolt
Posted 2 years 2 months ago #206872i found it a lot easier to use a long extension and socket through the passengers wheel side of the car
I used a foot long extension so the ratchet was beyond the body of the starter on the bolt.
For the nut I used an offset spanner on the nuts ( https://www.halfords.com/tools/hand-tools/modular-trays/halfords-advanced-8-piece-offset-spanner-set-modular-tray-332934.html ).
For the higher nut I used some insulation tape to hold the nut in the spanner as there was no way I could reach up and start the bolt by hand.
Replied by Delbourt on topic Starter Motor -How to remove/replace
Posted 2 years 1 month ago #206881My recollection was that beneath the water rail pipework access was limited to somewhere between 2 and 3 inches only.
Posted 2 years 1 month ago #206882
Just this past spring, when I had the starter off to change the timing belt, I painted the two nuts yellow to make them more visible, which I do think is helpful.
[size=10pt]Mark[/size]
95 MGF
Replied by Notanumber on topic Starter Motor -How to remove/replace
Posted 1 year 3 months ago #2132762003 MG TF 135 sunstorm
Posted 1 year 2 months ago #2133702003 MG TF 135 sunstorm
