Starter Motor -How to remove/replace
Starter Motor -How to remove/replace was created by David Aiketgate
Posted 12 years 9 months ago #129496I decided to replace it.
Disconnect the negative terminal of the battery before you begin.
Access the engine by removing the access panel. The starter motor is down here.
It was easy for me to remove the induction filter to get at the starter motor, by undoing this clip.
You can now see the starter motor.
Pull back the rubber boot from the main ((red) cable. Undo the nut holding the red and brown cables.
Remove the connector from the spade terminal.
The starter is attached by two M10 17mm head bolts through the bell housing into two 19mm nuts(NOT captive).
Pull out the starter. Here is the old and the new.
Replied by David Aiketgate on topic Starter Motor -How to remove/replace
Posted 12 years 9 months ago #129497Getting the nuts back onto the bolts is fun, and you need to get a spanner on to hold it while you tighten up and torque to 'kin tight.
Re-attach the red and brown wires onto the terminal bolt and tighten up the nut. Make sure the rubber boot is in place. Push the spade connector onto the spade terminal.
Reattach the induction filter.
Reattach the negative terminal of the battery.
Start car.
Replied by paulsmgf on topic Starter Motor -How to remove/replace
Posted 12 years 9 months ago #129499Please Log in or Create an account to join the conversation.
Replied by mowog73 on topic Starter Motor -How to remove/replace
Posted 11 years 10 months ago #149983[size=10pt]Mark[/size]
95 MGF
Posted 11 years 10 months ago #149988David
Posted 11 years 10 months ago #149990There are two types that fit the 1.8mpi - A magnetti Marrelli and a Bosch. Both have ten teeth.
The 1.6 starter has 12 teeth
Someone else also fitted a Rover 400 starter onto a TF with no problem.
Make of that what you will.
Posted 11 years 10 months ago #150007[size=10pt]Mark[/size]
95 MGF
Replied by Alfaman20 on topic Starter Motor -How to remove/replace
Posted 7 years 11 months ago #187482Please Log in or Create an account to join the conversation.
Replied by talkingcars on topic Starter Motor -How to remove/replace
Posted 7 years 11 months ago #187489A 17 mm bolt would be 17mm long, a 10mm bolt would be 10mm long.
Posted 7 years 11 months ago #187495David
- bryan young
Replied by bryan young on topic Starter Motor -How to remove/replace
Posted 2 years 8 months ago #204535Please Log in or Create an account to join the conversation.
Posted 2 years 2 months ago #206870Are the starter motors inchangable? In otherwords, can the starter from a later model TF be used on a early MGF? The reason I ask is that the price of starter for the early Fs is a lot more than for the later one for a TF.
I have just taken a 10 tooth starter off my mk1 VVC and fitted a 12 teeth starter........car starter better than she has ever done.......so yes, starters are interchangeable.
