IAC Valve.
IAC Valve. was created by David Aiketgate
Posted 14 years 4 weeks ago #16941
Does anybody have a spare working IAC valve?:dunno:
It's for a mk2 F, so it's the later type with 4pin in line connector.
Ta.
Replied by cjj on topic IAC Valve.
Posted 14 years 4 weeks ago #16954
Are you experimenting?
Replied by David Aiketgate on topic IAC Valve.
Posted 14 years 4 weeks ago #17018
CJJ;16954 wrote: Are you experimenting?
Nah the damn thing's playing up, and the usual spray of carb cleaner didn't work.:dunno:
Posted 14 years 3 weeks ago #17025
What's the symptoms? Hunting/bad idling?
Posted 14 years 3 weeks ago #17031
CJJ;17025 wrote: What's the symptoms? Hunting/bad idling?
The idle is perfect most of the time, but very occasionally it starts hunting badly 200-1500 revs. Usually a good rev or two and it settles down again.
Some days it's perfect.
Posted 14 years 3 weeks ago #17044
Managed to get one from ebay.:yesnod:
Posted 14 years 3 weeks ago #17061
Has it done this before? You seem quite confident that is what it is, so I'm assuming it has happened a few times.
Posted 14 years 3 weeks ago #17073
CJJ;17061 wrote: Has it done this before? You seem quite confident that is what it is, so I'm assuming it has happened a few times.
Yeah, it has. The thing is I tried cleaning it and the problem was immediately much worse. :doh:
Posted 14 years 3 weeks ago #17076
Hmm. Wonder what causes it. Maybe the piston or whatever is sticking. Do you fancy doing an autopsy to see how it works and what the problem may be?
Posted 14 years 3 weeks ago #17102
CJJ;17076 wrote: Hmm. Wonder what causes it. Maybe the piston or whatever is sticking. Do you fancy doing an autopsy to see how it works and what the problem may be?
You know me, would I be interested in taking it to bits?...much!:lol:
I've seen one of the earlier types taken apart and it was manky!
Posted 14 years 3 weeks ago #17118
Strange really, as the IACV shouldn't suck anything else but clean air. I think the breather pipes and charcoal cannester pipes etc are after the IACV.
Posted 14 years 3 weeks ago #17121
CJJ;17118 wrote: Strange really, as the IACV shouldn't suck anything else but clean air. I think the breather pipes and charcoal cannester pipes etc are after the IACV.
The Iacv connects directly from the inlet plenum back to the throttle body so will be able to suck breather fumes etc.:yesnod:
Time to create page: 0.519 seconds
