door card plastic bag thingymadoodlemajiggy
door card plastic bag thingymadoodlemajiggy was created by bensewell
Posted 11 years 9 months ago #103599
Wanted a passenger or maybe both sides. The plastic door card thing inside its like mega hard cling film / plastic film are they dear ?
Replied by pendle lass on topic door card plastic bag thingymadoodlemajiggy
Posted 11 years 9 months ago #103600
Not sure Ben, have you thought about using a thick plastic? or thin bubble wrap
I need to take Fizz's door off that was one thing Daz wanted to check, that there is plastic there or its fixed properly
Replied by onefastmoke on topic door card plastic bag thingymadoodlemajiggy
Posted 11 years 9 months ago #103602
bensewell wrote: Wanted a passenger or maybe both sides. The plastic door card thing inside its like mega hard cling film / plastic film are they dear ?
When I replaced one on my ZS a few years ago it was actually a really thick clear rubble sack that I used, fixed it round the edges with a small bead of silicone and did the exact same job :broon:
Keith
a hammer fixes all
The following user(s) said Thank You: bensewell, the singing bush
Replied by the singing bush on topic Re: door card plastic bag thingymadoodlemajiggy
Posted 11 years 8 months ago #105691
Cracking idea :)
Ben, I assume you mean for the green TF? It was missing when I bought it, the shite mechanic who replaced the window regulator didnt bother to replace it before I picked it up..
Last Edit:11 years 8 months ago by the singing bush
Last edit: 11 years 8 months ago by the singing bush.
Replied by John and Sue on topic door card plastic bag thingymadoodlemajiggy
Posted 11 years 8 months ago #105694
Builders grade polythene. Most merchants will sell off the roll.
If you use non setting mastic as per original you can remove and reuse if required. Or decent grade gaffer tape does the job.
The following user(s) said Thank You: David Aiketgate, the singing bush
Posted 11 years 8 months ago #105711
actual name for them is door shedders... rimmer bros has them for about £11 plus vat :omg:
Posted 11 years 8 months ago #105719
Worth £11 I reckon - especially if they are cut to shape :)
Replied by pendle lass on topic Re: door card plastic bag thingymadoodlemajiggy
Posted 11 years 8 months ago #105724
http://www.rimmerbros.co.uk/Item--i-EJD101450
not so sure Scott it doesnt look difficult to cut
Replied by bensewell on topic Re: door card plastic bag thingymadoodlemajiggy
Posted 11 years 8 months ago #105730
I'll cut you a bag from work for 11 quid
Posted 11 years 8 months ago #105736
we checked mine Saturday Ben and they are fine but id saved some thick clear plastic wrapping just in case :broon:
  • birks
  • Loves going topless!!!
Replied by birks on topic Re: door card plastic bag thingymadoodlemajiggy
Posted 11 years 8 months ago #105752
bensewell wrote: I'll cut you a bag from work for 11 quid
I'll cut you one and post it for £10 ;)
by birks
Posted 11 years 8 months ago #105757
i thought it might have been self adhesive but it isn't
Time to create page: 0.536 seconds
