Engine Bay Fan
Engine Bay Fan was created by Davem
Posted 11 years 7 months ago #111782
I need a engine bay fan for my 98 mgf.
If anyone can help I would appreciate it.
I did Leighs cut in check and found that the fan is seized with a blown fuse :doh: :doh:
Does anyone have any tips on how to remove/replace it easily. :-? :-?
Thanks Dave
[IMG]ht[/img]
by Davem
  • Visitor
  • Visitor
Replied by a Guest on topic Engine Bay Fan
Posted 11 years 7 months ago #111822
its not easy to get to as im sure your aware.ifyou remove the expansion bottle it gives you arm room.if you take the engine out its easy access is no problem
but the issue can be the small bolts snapping off.you may find that you may land up take the engine bridge,the alloy bit off the subframe.
again those bolts can snap as well,
so if the front alloy bit needs to come off. spray loads of oil on the bottom on the bolts on the bottom of the subframe.
you can find removing one simple item leads to rebuilding the hole dam car.I have some small air tools that can access these places if lucky.
but with this weather I doubt if you even need an engine fan lol
Replied by Mal7921 on topic Engine Bay Fan
Posted 11 years 7 months ago #111829
I have one you can have if you need one, just pm me your address.
Not the easiest things to get to, but doable with care.
by Mal7921
The following user(s) said Thank You: Davem
Replied by David Aiketgate on topic Engine Bay Fan
Posted 11 years 7 months ago #111847
It might be worth trying to free off the fan in situ. Loads of plusgas and a bit of to and fro.
Dave is in the Anitipodes, so an engine fan should be working.
You could always think laterally and mount a small 12volt fan in the lid vents to extract hot air.:shrug:
Last Edit:11 years 7 months ago by David Aiketgate
Last edit: 11 years 7 months ago by David Aiketgate.
Replied by Davem on topic Engine Bay Fan
Posted 11 years 7 months ago #111856
Thanks for all the help. I did get the fan moving but it is still tight and a bit "gritty" feeling. It was probably seized when I got the Mg 6 months ago and it has been driven on some hot days. The dash warning light does work when the plug is pulled. I will check that its operating correctly with a heat gun once I get the fan working. Thanks Dave
[IMG]ht[/img]
by Davem
Replied by Cobber on topic Engine Bay Fan
Posted 11 years 7 months ago #111857
David Aiketgate wrote: You could always think laterally and mount a small 12volt fan in the lid vents to extract hot air.:shrug:
I have fitted a pair of small extraction fans to the engine cover grill to my car, But I use them as boosters in conjunction with the existing engine bay fan.
The one's I fitted are from a quad bike, they look like computer fan but they're weather resistant. They do pump out a lot more hot air then just the standard set up.
But I don't know that I'd like to rely solely on them.
I you were here in Melbourne I could give you a hand sorting it but I see you've got NSW plates so I assume your up in Smegtown, (Sydney) that's a bit far from here to be convenient for you.
Posted 11 years 7 months ago #111858
Davem wrote: Thanks for all the help. I did get the fan moving but it is still tight and a bit "gritty" feeling. It was probably seized when I got the Mg 6 months ago and it has been driven on some hot days. The dash warning light does work when the plug is pulled. I will check that its operating correctly with a heat gun once I get the fan working. Thanks Dave
If it "feels gritty" I'd say the bearings in the fan are well and truly rooted!
Posted 11 years 7 months ago #111861
Malcom has kindly offered to pull the parts I need out of his fan and send them over. This will save on weight and postage. I just need to pull mine out and apart tomorrow.
Thanks Malcom
[IMG]ht[/img]
by Davem
Posted 11 years 7 months ago #111920
No problem, have the full assembly but would be easier to ship just the motor but can send the whole unit if needed. :-)
by Mal7921
Posted 11 years 7 months ago #111925
:broon: :broon:
Posted 11 years 7 months ago #111969
Quite simple to strip down the assembly , 2 bolts hold the outer guard and mounts on while the main fan is held on with a single clip .
by Mal7921
The following user(s) said Thank You: Leigh Ping, Davem
Posted 11 years 7 months ago #112038
Thanks for help Cobber and Mal. Will try to get it out today. :broon: :broon:
[IMG]ht[/img]
by Davem
Time to create page: 0.546 seconds
