Sorted
- ashleyfrazer
- Apprentice MGer
Ash
Sent from my S24 Ultra using Tapatalk
I’ve no doubt there’ll be suppliers where a couple of quid might be saved but whenever I’ve received, via carrier or picked up in person, everything has been spot on.
They have one of the tidiest workshop & warehouse I’ve visited; the parts they fit come out of their stores & you receive the same.
I’ve never had to draw a mounting hole or debur any part they have supplied & isn’t that worth a few more quid, when you’re in the drive, sprawled under the car with it spitting for rain. You then offer up a heavy item only to find that your inexpensive part doesn’t fit.
It’s something to consider.
*I had better clarify the term hidden joint refers to the joint in the downpipe which is hidden by the mesh flexi section - not anything involving Rixlas.
Brakes need not be top drawer but neither should you consider bargain bucket knockoffs from a back street in Bombay.
Tyres although less critical on an f than on a tf, should focus your mind & if your exhaust & cat aren’t up to scratch your not going to get an MOT.
Running any car on a budget is a balancing act but our cars are well supported by companies who had the foresight to lay in new old stock parts when you have no other route & because some ex owners haven’t had the staying power, there are bags of donor vehicles.
My pet scrappy doesn’t have any of our cars on at the moment but there are a number of parts that bleed through from Rover cars. I spent a full £3 earlier on oddments including OEM fuses, Littlefuse fuses blow at the value moulded on to them; I tested several unbranded fused a while back & non failed at the rated value. Not so with OEM.
Don’t loose heart, once sorted you’ll be rewarded with some great drives. Unless, that is, you live in a low emissions prison.
Where as better quality cats have a proper ridgid honeycomb matrix, this too can break up but it takes a lot longer to do so
Local exhaust fitter will fit all for reasonable cost also
Glad you got good results from mgfntfbitz; I don't know of anyone who has been let down by them, absolutely straight-up folks. You are definitely in the right place for advice here as the experience on offer will help you avoid the false economies too.
SC
