Air Conditioning - Retrofit
- Paulontour
talkingcars wrote: Nice one - people often rubbish the idea of aircon on a convertable but it was sold to me by a BMW M3 owner - the interior of a soft top is inevatably damper than a tintop, the heated air from a/c is drier so clears the screen much quicker.
Look foward to the finished results.
Thats always going to happen. The air is not heated its just circulates through an evaporator and removes all the moisture and aids clearing the screen. I dont rubbish the idea of aircon in a convertible i just dont see the point, I mean aircon is used primarily in the height of summer when really all you want to do is enjoy top down motoring and not just sit in an air conditioned bubble. As for retro fit why not buy one with A/C and save yourself a lot of hassle. But on the other hand top marks for having a go
- quick_spider
Replied by quick_spider on topic Re: Air Conditioning - Retrofit
Posted 13 years 11 months ago #62115It's also about the journey rather than the destination...
- Jack of Hearts
- Once more into the breach
Replied by Jack of Hearts on topic Re: Air Conditioning - Retrofit
Posted 13 years 11 months ago #62116It's all well and good saying go out buy one with ac. But I tried that. Went to see dozens. And they were all sheds. There also quite rare. Not many people opted for the ac so you limit the field even more.
- a Guest
- User
- Leigh Ping
[size=10pt]Mark[/size]
95 MGF
- adamelphick
Replied by adamelphick on topic Re: Air Conditioning - Retrofit
Posted 13 years 11 months ago #62222Please Log in or Create an account to join the conversation.
- quick_spider
Posted 13 years 11 months ago #62228Please Log in or Create an account to join the conversation.
- quick_spider
Posted 13 years 10 months ago #67307If you're using mk1 wiring, the AC switch fits with no modding. The Recirc switch has different keys, but is easy enough to doctor with a scalpel (note pinouts are identical for the switch sub-loom):
Wiring: John (Jack of Hearts) very kindly sent me his TF AC body loom which I've stripped back all the dross so here's what's left with labels. (Ignore the fog light parts - that's because he has a poverty spec 160!) It turns out the TF & Mk2 is entirely integrated with the body loom. The mk1 has a seperate front bay loom as pictured earlier (join is where the red line is)
1: Trinary Switch (on dryer)
2: Relay Pack
3: Fusebox connections (x2) - only one on my MGF loom which I need to investigate
4: Fan Connections (x2) - on MGF loom this has a separate connector to plug into the existing fan connection. For TF/mk2 F this replaces it. (John, just unplug your old one and tape it up)
5: Connector to Switch Sub-Loom - connects just above evaporator
6: To dashboard feed - I'll add pictures later showing which pin once I've done the rest of my car loom
7: To ECU/Engine Bay. 4 pins to go into small ECU connector, 2 to go into one of the other body/engine loom interface plugs.
There's also couple of earths up near the front fog wiring.
As you can see, it'll be significantly easier to add this to an existing car, rather than swap the whole body loom.
- Jack of Hearts
Posted 13 years 10 months ago #67313Your still going to have to do the masking tape thing again;)
- quick_spider
Posted 13 years 10 months ago #67977MG/Rover in their wisdom didn't bother to list in the EPC how many of each size of o-ring you need, or the locations. This is especially annoying since the ones you need most of are priced at £2.23 + VAT each.
I'm going to try buying some tomorrow through Land Rover as they seem to be cheaper.
From what I can gather so far you require:
1x JYX100150 (£0.45 each - I bought 10x if anyone needs one!)
1x JYX100160 (£0.45 each - I bought 10x if anyone needs one!)
4x JUU100220 replaced by JUU000070SLP (£2.23 each) or try Land Rover JUU100220L
4x JUU000060 replaced by JUU100230L (£1.27 each - presume because it's a Land Rover part no)
4x JUU100240 (£2.23 each) or try Land Rover JUU100240L
I'll update tomorrow when I've got some feedback on Land Rover prices.
