Heater Blower Resistor Replacement (On an AC Car)
- quick_spider
Heater Blower Resistor Replacement (On an AC Car) was created by quick_spider
Posted 12 years 2 months ago #81111I bought a rezpax repair kit which consisted of 3x coil resistors to replace the old ones. I also bought a knackered heater resistor pack so I could do a nice quick swap. Sadly, either they're different between the F and TF, or I was sent the wrong one.
On a non-AC car, if you take the glove box out, you can get access easily enough to the 2x screws which hold the resistor pack in.
On an AC car, the evaporator is in the way.
Here's how I got access without taking the dash out, or de-pressurising the AC system.
Remove the air intake box under the bonnet (This is lots easier if you've got the later 'snorkal' type - I'd recommend fitting one of these to prevent swimming pools in the footwell)
This will give you access to the air intake duct which is secured by 4x screws and a nut - you should be able to see 2x screws.
Remove the glove box. On the lefthand side you should see 2x screws holding the intake duct in. The final nut is in the top left of the evaporator unit assembly.
You should be able to remove the duct which will give you easy access to the heater resistor screws through the bulkhead from the front bay.
Replace/Repair the unit and re-fit - the soldering is pretty straight forward, although it helps if you have a de-soldering gun to remove all the old solder.
- quick_spider
Replied by quick_spider on topic Re: Heater Blower Resistor Replacement (On an AC Car)
Posted 12 years 2 months ago #81144Please Log in or Create an account to join the conversation.
Replied by talkingcars on topic Re: Heater Blower Resistor Replacement (On an AC Car)
Posted 8 years 2 months ago #172414quick_spider wrote: The resistors themselves are the same, but the plastic casing with the connector moulded in appears to be different between the f/tf (or I was sent the wrong one!)
The MGF/TF one is the same but they are different to the ZR/ZS one.
Replied by David Aiketgate on topic Re: Heater Blower Resistor Replacement (On an AC Car)
Posted 8 years 2 months ago #172415David
- bluesparkuk
- Journeyman MGer
Replied by bluesparkuk on topic Re: Heater Blower Resistor Replacement (On an AC Car)
Posted 8 years 2 months ago #172416Please Log in or Create an account to join the conversation.
Replied by whizzyboy on topic Heater Blower Resistor Replacement (On an AC Car)
Posted 7 years 2 weeks ago #182241all the best
Paul Thomson
Replied by talkingcars on topic Heater Blower Resistor Replacement (On an AC Car)
Posted 7 years 2 weeks ago #182281Pop up an introduction thread and tell us a bit more about yourself.
James
Replied by tui on topic Re: Heater Blower Resistor Replacement (On an AC Car)
Posted 4 years 10 months ago #192499Please Log in or Create an account to join the conversation.
Posted 4 years 10 months ago #192507tui wrote: Revived once more! :woohoo: ……….
Which, the thread or yourself?
Posted 4 years 10 months ago #192508
Both!!
