Extending fob / alarm operating range.
Extending fob / alarm operating range. was created by PQD44
Posted 10 years 7 months ago #144138
The problem?
When I first got my MGF I changed the battery in the fob because I had to be stood next to the car (almost with the fob pressed up against the window) to operate the alarm / central locking. New batteries in and ..... didn't make any difference. Having put up with this years I decided to see what could be done about this annoying quirk.
Tools needed:
Cross head screw driver, soldering iron, heat shrink tubing or insulating tape.
The Fix
I read that if you remove the passenger foot well panel (retained by two screws),
locate the yellow aerial cable that is coiled and taped up to the main wiring loom, straighten it out and tape it you should find the operating range is increased.
:-? I searched for a couple of minutes but there was no coiled yellow wire?
At this stage I need to say that I have a MGF MY2000 ( Mk II ). Apparently on the original MGF this was where the yellow aerial cable was located. After a bit of research I discovered that MG Rover had the ingenious idea to "cure" the range problem on the MGF MY2000 and MG TF by routing the wire to the hazard warning switch's connector block. :slapme:
So pop out the hazard warning switch and ....
... sure enough, there is the yellow aerial cable pictured at the top left of the block. As you can see this has no corresponding connector on the Hazard warning switch. Disconnect this wire and attach a 52.5cm (see explanation below) length of insulated wire to it using a soldering iron. I then used heat shrink tubing to cover the joint and the other end of the wire (this has to be done so that the aerial wire does not touch anything metal)
The fob operates at a frequency of 433MHz in the UK which is a wavelength of approximately 70 cm, the standard aerial wire is a 1/4 wavelength or 17.5 cm. You can add 17.5 cm to create a 1/2 wavelength or 52.5 cm to create a full wavelength aerial.
Next feed the new aerial cable down to the passenger foot well.
I then tried the aerial extended under the glove box and got a good improvement in range. I then ran the aerial along the center of the car (it ended by the side of the handbrake lever). This gave even better results and I can now operate the central locking from about twenty feet from the car :woohoo:
If you want to try and further improve the operating range I have seen a way to extend the aerial in the fob , click here.
There is the old trick of placing the fob next to your head to extend the range but my quick fix means you can have an extended range and keep your dignity.
Last Edit:10 years 7 months ago by PQD44
Last edit: 10 years 7 months ago by PQD44. Reason: annotate photo
The following user(s) said Thank You: psymon, David Aiketgate, peter81, mowog73, Leigh Ping, Bob, Blow-in, cairnsys, Davem, Deep Diver and 7 other people also said thanks.
Replied by Baytown on topic Re:Extending fob / alarm operating range.
Posted 10 years 7 months ago #144142
Brilliant info. Thanks for this as Ive never been impressed with the remote range on my 04, even though Technozen were happy with my fob. I'll see if I can improve my Aussie car with the different 315 MHz fob.
I'll post how I go.
Well done.
Ken
Last Edit:10 years 7 months ago by Baytown
Last edit: 10 years 7 months ago by Baytown.
Replied by David Aiketgate on topic Re:Extending fob / alarm operating range.
Posted 10 years 7 months ago #144143
Nice one, Paul. :broon:
I hadn't heard of the aerial wire being in the hazard flasher plug before. :nonod: So well done. :clap:
Guess where I'm going now! :whistle:
Replied by PQD44 on topic Re:Extending fob / alarm operating range.
Posted 10 years 7 months ago #144147
Baytown wrote: ... I'll see if I can improve my Aussie car with the different mHz fob. Operates on a lesser freq than UK spec cars, in the 300 range.
Ken
I think yours will operate at 315MHz so it will have a wavelength of 95cm. Assuming it has a 1/4 wavelength aerial, 23.75cm to start with, you will need to add a multiple of this; 24, 47.5 or 71 cm to achieve an improvement.
The following user(s) said Thank You: Davem
Replied by Badger on topic Extending fob / alarm operating range.
Posted 10 years 7 months ago #144150
PQD44 wrote: The problem?
Tools needed:
The Fix
I read that if you remove the passenger foot well panel (retained by two screws), locate the yellow aerial cable that is coiled and taped up to the main wiring loom, straighten it out and tape it you should find the operating range is increased.
Attachment not found
This is still WIP for the Pektron unit, we have a thread still going from a couple of weeks ago; I doubled the length of the aerial cable as per my calc in this link http://www.the-t-bar.com/forum/9-mgf-tf-pitstop/91363-key-fob-range?limitstart=0#142469
There is a slight improvement but it's still poor, however I have found there should be a multiplier of around 0.91 in the sine wave calculation for multicore plastic sheathed cable and I am still playing around with the cable length, hopefully have some good info for the Pekton unit by the end of the week.
Brian.
by Badger
Posted 10 years 7 months ago #144155
PQD44 wrote: Thanks Brian, hadn't seen that, I've only been back on the T-Bar for two weeks.
If we use your 0.91 multiplier for the multicore cables then the length to add should be;
~48cm for the UK and ~65cm for countries using the 315MHz frequency. :broon:
It think it should be multiply the sum by 0.91, so would be something like 314mm for 1/2 wave @ 433mhz. or:
300 / 433 / 2 x 0.91 = 0315242 which will give about 315.2 mm for 1/2 wave
Will let you know if it's any better when I progressively chop it down.
Brian.
by Badger
Replied by PQD44 on topic Extending fob / alarm operating range.
Posted 10 years 7 months ago #144156
Look forward to your findings. Let me know and I'll update the best length to add in the original post of this how to. :broon:
The following user(s) said Thank You: Badger
Replied by peter81 on topic Extending fob / alarm operating range.
Posted 10 years 7 months ago #144164
I asked myself where is the yellow wire for 5 years in my F, amazing discovery! :woo2:
:clap:
by peter81
Replied by DavesZed on topic Extending fob / alarm operating range.
Posted 10 years 7 months ago #144537
Well done, great find!
Did this this morning and it works a treat!! Much improvement over what I was doing before. Not so good from the rear but still better though B) :drive:
Thank you :beer:
Replied by Uncletone on topic Extending fob / alarm operating range.
Posted 10 years 7 months ago #145054
Excellent Paul well done that man. Now I can open the doors from anywhere. m
Beats standing on your head with the fob between your knees any day.
Great job
Tone
Replied by John and Sue on topic Extending fob / alarm operating range.
Posted 10 years 7 months ago #145066
A great how to, but we really don't have a range problem on our TF. Works from about 10 metres away from any direction of approach.
Maybe they got it finally sorted at the end of production?
Posted 10 years 7 months ago #145071
John and Sue wrote: A great how to, but we really don't have a range problem on our TF. Works from about 10 metres away from any direction of approach.
Hi John, we had another thread on this at the same time (TF Pekton unit related)
This was the reply from Paul (Technozen)
"The Pektron SCU has no external antenna, the internal radio receiver board has an antenna on the circuit board. Poor radio range on these units is usually caused by the radio receiver board itself, it's a common problem" (Thanks Paul)
Brian.
by Badger
The following user(s) said Thank You: John and Sue, DavePro
Time to create page: 0.680 seconds
