Rear Track Control Arm Service RDG000570 - Bushing
- verplant23
- Apprentice MGer
Rear Track Control Arm TF - Poly Bushing was created by verplant23
Posted 11 years 7 months ago #153928
Here are some pictures about bushing the rear trailing arm of a MG TF: http://www.rimmerbros.co.uk/Item--i-RGD000570
The bushes i used were these
http://www.rimmerbros.co.uk/Item--i-RGD000570POLYOUTER
http://www.rimmerbros.co.uk/Item--i-RGD000570POLYINNER
The reason i´m posting this is i needed to repair/change these arms on my tf. looking around in some boards and only found answers like:
this item is not serviceable, you have to buy new oneoryou can only replace inner or outer bush didn´t remember.
so but why should rimmers sell this bushes.... so have a look
hope i could help you guys.
Tools needed:
A vise
Some nuts like 32mm 28mm 17mm
a heavy hammer
hammer time
the inner bush at first looked easy to get out. put the bush with the nut in the vise and began to press it out.
Nuts 32mm and 17mm.
then i realised there is an outer ?bush? on the inner end need to press out to get the poly fitted.
so i needed to press it out. used a 28mm nut fitted perfect to this bush. and again the 32mm nut.
some heavy hammering and it came out.
the outer end was a bit harder to get out. until i realised that there is only one direction you can get it out.
first remove the rubber seals by removing the wire clamp.
to find out in which direction you can press this bush out look at my pictures.
will add some pictures about the finished and painted job later after sand blasting this stuff.
have a luck
hope i could help you guys.Tools needed:
A vise
a heavy hammer
Nuts 32mm and 17mm.
have a luck
Last Edit:10 years 11 months ago
by verplant23
Last edit: 10 years 11 months ago by David Aiketgate.
- verplant23
- Apprentice MGer
Last Edit:11 years 7 months ago
by verplant23
Last edit: 11 years 7 months ago by David Aiketgate.
Replied by David Aiketgate on topic Service RDG000570 - Bushing
Posted 11 years 7 months ago #153931
Fantastic.
I've amended the title a little and clicked insert on the photos to facilitate this fabulous addition to our how tos.
- verplant23
- Apprentice MGer
feel free to do so. my text could be more detailed but sometimes pictures could tell more than 1000 words
will try to answer if there are any questions
thanks a lot
thanks a lot
by verplant23
Posted 11 years 7 months ago #153935
To clarify, the odd bottle shaped bush is a replacement for the rose-joint inner. Yes?
That is a great find, because as you say, the common wisdom is that it can't be replaced.
Which way round does it fit?
by David Aiketgate
- verplant23
- Apprentice MGer
picture 9 you see the bush as you said formed like a bottle? this is the bush for the outer end of the arm(fitted to the hub). this is what is called a rose joint?
the original bush can only be removed in one direction. there is an edge on the other side you can see it on picture 7 and picture 6.
the way you have to put in the polybush is shown in picture9 and 10
by verplant23
- verplant23
- Apprentice MGer
- verplant23
- Apprentice MGer
like I said I will add some pictures when the bushes are fitted. First i have to sand blast and paint everything.
it seems like rimmers are the only one who supply these bushes. when i got my package i was a bit confused because poly printed strange definition on it. like toe arm bush 38Y and on the other lower forward link 38U.
it seems like these package were reused. or something like this.
by verplant23
Last edit: 11 years 7 months ago by David Aiketgate. Reason: sp
- verplant23
- Apprentice MGer
And the other side more in detail. now you can take a look on the "outer metal bush" on this side. the poly one has a equal outer metal bush
by verplant23
- verplant23
- Apprentice MGer
Ok but this balljoint has nothing to do with rgd000570 or because there is no balljoint on it? Sorry my name "verplant(23) " means something like "always confused(23)" in english
by verplant23
Posted 11 years 7 months ago #153945
Yes. Sorry my fault. :doh: I've confused you.
What I meant was that on the MGF, this arm is the same except that one end is a balljoint rather than this end on the MGTF arm.
So your how to is relevant to the MGF arm as well as the TF arm...
The following user(s) said Thank You: verplant23
Time to create page: 0.727 seconds
