Rear Track Control Arm Service RDG000570 - Bushing
- verplant23
- Apprentice MGer
Yes perhaps the the rosejoint Bush will fit to the MGFs arm aswell.
And perhaps also to the long trailing arm on the TF.
I will check the TF next time i am under my car cause i have to replace it too.
Someone should check out the mgf Option.
- verplant23
- Apprentice MGer
one side left turned thread one side right turned thread
(17) Sandblasted
(18,19,20) Epoxy rust protection
Replied by phil-hex on topic Rear Track Control Arm Service RDG000570 - Bushing
Posted 11 years 7 months ago #154139firstly after undoing the bolt i moved it slightly to the side and got the blow torch out and burnt the rubber out
the first side took some pressing out using sockets and a Gclamp
once i had seen what i was up against the second side came out in seconds after a quick burn out and a tap with a screwdriver to bend the collar in
then it was a simple case of pressing the polybushes home using a Gclamp and a socket
Replied by David Aiketgate on topic Rear Track Control Arm Service RDG000570 - Bushing
Posted 11 years 7 months ago #154143ps You haven't got any bigger photos have you?
- verplant23
- Apprentice MGer
Replied by verplant23 on topic Rear Track Control Arm Service RDG000570 - Bushing
Posted 11 years 7 months ago #154174need some repainting on some spots
also waiting for a new nut . ordered from mcgill
- verplant23
- Apprentice MGer
Posted 11 years 6 months ago #154305a cheap option
thread left turned thread right turned connection. each side is M16x1,5
found it also used by DAEWOO, OPEL, VAUXCHALL
OEM Part number
322575
0322575
07846696
Replied by Dave C on topic Rear Track Control Arm Service RDG000570 - Bushing
Posted 5 years 3 weeks ago #196137first post so be gentle with me resurrecting such an old post butI am properly stuck
i have adjustable arms on mine and have got the old hub end bush out and trying to get the new poly bottle shaped bush in but can’t get it in, have split 2 now.
I’ve tried it by trying to wind the complete bush in but it gets to a point where the bush stops moving and just the metal centre continues to go in. Tried then with poly bit first and get the metal centre in after and it just splits the bush. I am using lots of lubricant but to no avail.
i am trying to do this with the arm on the car, how did you guys manage it? What am I missing?
thanks in advance for any wisdom
Replied by talkingcars on topic Rear Track Control Arm Service RDG000570 - Bushing
Posted 5 years 3 weeks ago #196142I think I would start by getting the arm off the car so you can really get it cleaned up and study the parts to see if any trimming is needed.
Let us know how you get on.
James
Posted 5 years 3 weeks ago #196154
You are trying to put it into the end that had the Rose joint previously installed?
Have you removed the old outer collar of the rose joint?
the poly bush should press in reasonably easily, them press the steel sleeve in.
Posted 5 years 3 weeks ago #196156I am trying to do this whilst keeping the arm on the car as if I take it off and then can't get it back on i'm a bit screwed.
David - yes the rose jointed end at the hub, the one that should take the bottle shaped poly bush. About the collar, do you mean the plastic one? If yes then that came out with it. Or is there a metal one?
Posted 5 years 3 weeks ago #196157https://www.the-t-bar.com/forum/21-david-aiketgate-s-guides/94040-mgf-rear-track-inner-bush-joint-how-to-replace
Posted 5 years 3 weeks ago #196158Sorry for being a bit simple on this
