Steering column
Will search YouTube for help
many thanks
Kenny
I hope for your sake that isn't the case and they're just loose!
I do have a spare steering column stashed away somewhere I should see if can find it, and see it that sheads some illumination on the subject
Is yours an adjustable or a fixed column?
I’ve a Mk1 f column, I’ll look later.
The illustration is of a later, adjustable offering from a later car than yours, if your car has the drop leaver to adjust the hight, that implies a retro fit & if done poorly, that could be the root of your problem. Get it looked at immediately!
There are two ways to change from fixed to adjustable; removing the original fixing points & welding in new, or a correctly engineered adapter plate, using high tensile bolts. I have taken the second method & find it satisfactory, mind you it was a lot of work & the amended position is little different from standard.
yes my car is 1999 and it does have the adjust
lever mechanism.
I am not driving at the moment due to illness. My son is going to have a look at the car for
me. Are/is everything accessible or does he need to dismantle the dash?
If you split the cowling around the auxiliary stalks/ignition key (three screws, side clips & a struggle) you should, having contorted yourself into a position normally only available to the double jointed, you & amongst the jungle of wire, will see the mounts.
I’ll leave it for you to assess, however if you wish to photograph what you have & post them on here I’ll take a look.
Where abouts are you?
later (MY) column fitted to my 1999.
Located the two 10mm bolts fastening the column to the dash. Both were tight but for completeness slackened off and retightened.
On re investigation the side to side movement seems to be in the mechanism itself.
Clamp lever pushed up as far as it will go. Mount bold very tight. Column moves side to side within the up/down mechanism.
is this mechanism dismantle-able or is a replacement needed.
happy days
kenny
These devices are die cast “clips” held onto the shaft bracketry by nylon pegs. These are designed to shear if the steering column collapses during an accident; they are a loose fit in the mounting bracket if these nylon pegs are absent or sheared for some reason.
I would be taking the column out to inspect it on the bench. The contortionist is better placed to undertake this job or a grand child.
As with many jobs on our cars the age diaspora, here present, mitigates against doing jobs on a quick turnaround basis.
Does anyone else recognise these comments in there mechanical transactions?
I have bending down jobs to do, procrastination is getting in the way; that & the cold garage.
Oh my giddy aunt.
lever mechanism.
Wishing you a speedy recovery.
The bolts on the adjustable column are further apart than the bolts on the non adjustable earlier column.
How did the installer get around this?
It sounds like they didn't do a very effective job.
The bracket should have been welded to the cross bar that lives under the dash.
You (or your son) should be able to access the mounting point by removing the speedo.
Also did they change the wiring and the ECU to the later version?
