The MGB is one step closer
Craig
Let me know how you get on with the Flame Thrower and please send me some pictures of your car with the wheels fitted, I would like to add a picture to my website (www.upgrades4mgs.co.uk) page on the wheel choices.
Is your engine tuned? Just asking because I have normally found a richer needle in the 1.5" SUs better than the 1.75" SUs which seem to run too rich and start to cause problems on standard engines, even with stage 2 heads.
- Supercover
cjj wrote: Supercover has been nominated for the Nobel Peace Prize.
Social hand grenades don't exist.
MartinW wrote: Are the rims from an Australian company, Craig? Those rims look similar to the rims used on the last MGBs and also on the Triumph Stag. I think they also do replica Minilite and Wolfrace style rims It will look nice with these. If your axle is a wire wheel unit then it will be slightly narrower than a 4-stud axle so you might need spacers especially with the 205 tyres or have you got a Sebring wide arch kit?
Hi Martin, the rims are made by Performance Wheels in South Australia, the same company that do the Minilite replica "Superlite". We have made 13mm Spacers for the rear, unfortunately I don't have sebring wide arches so I still have to grind a bit off the lip on the guard.
As soon as the weather clears up, I'll take some shots for you and I'll let you know how the flamethrower goes.
As it will be some time before the 1.75" SU's and the new top end is built, I'm putting AAA needles in the 1.5" SU's to tide me over.
Cheers
Craig
I ran AAA needles in HIF4s on mine along with the deep K&N filters and it certainly seemed to work well with that set-up.
- bryan young
- Rich in Vancouver
Replied by Rich in Vancouver on topic Re: The MGB is one step closer
Posted 12 years 9 months ago #38611I had a Pertronix cartridge in a stock distributor in the blown 1800 in my ZA and never had any problems with it. It is certainly "fit and forget". Just make sure that you have the polarity correct when fitting it as you can fry the unit if it is hooked up reversed.
Looking forward to seeing some pics of your B on the track! :broon:
Mine is typical, the LHS viewed from the back = nearside here in the UK has much less clearance. I have slighty oversize radials on wire wheels. They are 155 v the factory 145 from memory, I dont run low profiles on that car they are 82 section.
Those wheels look great, it will be great fun on track, a tweaked MGB can still give a good account of itself 50 years after its launch.
- Luckymarine
The lines of the older cars are just a class unto themselves and are hard to beat.
If you can live with almost zero luggage space the MGA has fantastic looks, and sells for a lot more so you might mot lose too much on a rebuild. They also weigh less and have less drag so go better for an equal tune B series engine.
Now some MGA porn.
The green one is a twin cam, the red one has a cross flow ali head, both cars have the 5 speed gearbox conversion. The owner of the red one also has an LE500.
- Rich in Vancouver
Posted 12 years 9 months ago #40480F-U-N! :broon:
