Non MG problems... Boiler Kaput
Replied by John and Sue on topic Re: Non MG problems... Boiler Kaput
Posted 12 years 1 month ago #77203
Worcester Bosch gets my vote. We have one, as does our daughter.
Replied by Mr Forgetful on topic Re: Non MG problems... Boiler Kaput
Posted 12 years 1 month ago #77235
Ben
Code L F (flashing)
1) Press the reset button (little one) in the middle just under the “display panel” showing the code error
2) Trying switching off the mains supply to the boiler (fused unit somewhere by the boiler) switch back on and press the ignition switch on the boiler
3) Check the condensation pipe that comes out of the bottom of the boiler and leads to a drain somewhere. This can block up and cause the problem you have. It is probably connected from the bottom of the boiler to a piece of plastic piping by a rubber connector – pull off and if loads of water come out (well a bit anyway) it is the cause of your problem This water is from the condensing and needs to be able to drain away so – clear the drain pipe.
NB I am NOT an electrical/plumbing/engineer but I HAVE done this twice (once for my house and once for my daughter’s). The latter worked for her.
PM me if i can help further as I did in fact fit a new PCB to my boiler - I got one from a chap on fleabay for about £75 - new the plumber quoted about £400. Needless to say, both boilers are (still, fingers crossed) A OK
Ted
The following user(s) said Thank You: David Aiketgate, bensewell, groovylee
Replied by David Aiketgate on topic Re: Non MG problems... Boiler Kaput
Posted 12 years 1 month ago #77239
Way to go Ted!:broon:
Replied by bryan young on topic Re: Non MG problems... Boiler Kaput
Posted 12 years 1 month ago #77319
I would go for Worcester every time, I did a Structural Survey on a house for a friend (i am a Surveyor) and the Worcester boiler ther was over 20 years old, been serviced by them and was still going strong :woohoo:
Replied by bensewell on topic Re: Non MG problems... Boiler Kaput
Posted 12 years 1 month ago #77326
Thanks all I'm waiting for the repair chappy if he can fix it I just pay 50 that's all if he doesn't I don't pay anything and I will get my mate neal to sort me out a new one. He shook his head when I mentioned ideal and said the council had to remove them as they were not that reliable
Posted 12 years 1 month ago #77353
Complained to the bank saying hurry up. I'm covered up to £500 per claim so hopefully all is well :)
Hopefully a new part and sorted! I reckon if I keep moaning about twins not coming home due to faulty heating then might be sorted by tomorrow.
I will get a quote up front before they start good advice allan. :woohoo:
Posted 12 years 1 month ago #77354
just had a chat with the engineer...
says its the condensing trap blocked so will watch him do it and see what's going on :) he says it might be full of crap and junk so might be a 15 mins job. Sounds just like what Ted said so cheers :)
Fingers Crossed !
Posted 12 years 1 month ago #77367
The boiler in our last hoouse suffered from this: there is usually a bottle in the boiler casing that collects the condensate and drains it to an external drain, If its that it will be a quick fix.
Posted 12 years 1 month ago #77369
Last winter a lot of new build houses had these problems when the condensate pipe froze solid. The builders had run the pipe down the external wall of the house without insulation. Not surprisingly, entire estates of new houses were without heating! cough... Barrett... cough!
Posted 12 years 1 month ago #77518
So the engineer came out. Emptied some water out and cleaned a plastic part. Put the boiler back together and working fine. I set it to on and left for the hospital.
Just come back and guess what.....
ITS F-ING broke again.....
ARRRGGGHHH!
So now engineer will ring me at 10am tomorrow so more faffing about, leaving the wife in hospital on herself with the twins.
NOT HAPPY!
That is all, rant over.
Posted 12 years 1 month ago #77568
bensewell wrote: So the engineer came out. Emptied some water out and cleaned a plastic part. Put the boiler back together and working fine. I set it to on and left for the hospital.
ARRRGGGHHH!
NOT HAPPY!
Get rid of the bloody thing :rant: :rant: :slapme:
Time to create page: 0.566 seconds
